MPG pendant interface 7I96s
- d3m0n54in7
10 Oct 2025 00:55 #336178
by d3m0n54in7
MPG pendant interface 7I96s was created by d3m0n54in7
Since I was last asking for assistance, I opted to switch over to a 7I96s board. I am having issues getting a cheap MPG pendant to jog axes in the Axis GUI. I have confirmed that the encoder works as well as the dead-man switch allows the signals I've designated as axis selectors and step values to trigger appropriately. I have seen forum posts about joint vs axis jog being toggled through the use of homing. (joint vs teleop) I utilize the Home all button to zero out the display before attempting to jog any axis. Using Halshow, I am able to see the joint-select-(a-d) and joint-incr-(a-d) trigger as well as the axis-selected-count value count up and down. I used the PNC wizard to setup the pinouts and didn't see "Axis select" as an option but did have "Joint select" available. I assume, based on what I've read about the 2.9 update that this wouldn't be an issue as I'm just using a standard 3 axis cartesian XYZ setup with possible expansion to XYZA once I have more confidence in using Linux CNC to actually run my machine.
It's probably something overly simple like linking joints to axes in a different way than PNC did by default or just a need to add a switch to convince the machine that it's been homed.
I've attached the Hal and Ini files for review.
10 Oct 2025 19:40 #336216
Replied by andypugh on topic MPG pendant interface 7I96s
I think that the problem is inconsistent HAL signal naming.
You haveThen later in the file:
You need to connect the hm2_,,, pins to the halui.... (and motion....) pins.
Use the same signal name (the first term after "net") to link:
hm2_select pin / axis.L.jog-enable / joint.N.jog-enable
hm2_mpg_counts / axis.L.jog-counts / joint.N.jog-counts
You will also need to work out logic to set the scale:
(probably a mux block) axis.L.jog-scale joint.N.jog-scale
For initial testing, try:
(change the setp to 0.01 if using inches)
If that works, then configure the jog scale (but to help with that we wiuld need to know whether the MPG binary-codes the speed selector or has a pin for each speed)
(This is using the pins from "motion" which are slightly preferable to the halui pins. However HALUI supports analog jog mode, so has its uses.)
linuxcnc.org/docs/stable/html/man/man9/motion.9.html
You have
net joint-select-a <= hm2_7i96s.0.inm.00.input-01net axis-select-x halui.axis.x.selectYou need to connect the hm2_,,, pins to the halui.... (and motion....) pins.
net jog-scale => axis.X.jog-scale joint.0.jog-scale
net jog-scale => axis.Y.jog-scale joint.1.jog scale
net jog-scale => axis.Z.jog-scale joint.2.jog-scale
setp jog-scale 0.1(change the setp to 0.01 if using inches)
Time to create page: 0.094 seconds
