hal configuration
  • hanz24
  • hanz24's Avatar Topic Author
  • Visitor
  • Visitor
27 Oct 2025 23:11 - 27 Oct 2025 23:56 #337322 by hanz24
hal configuration was created by hanz24
I’m currently learning LinuxCNC with EtherCAT, following several tutorials such as those on YouTube by MetalMusings. I’m trying to connect one servo and a servo drive to make it move with LinuxCNC. I’ve followed the video and adjusted the configuration according to my slave device.However, I’m getting an error like the following. I’ve already made sure that the XML file and HAL pins are correctly matched. Maybe I missed something, or there’s something wrong with my XML/HAL file.
Machine configuration directory is '/home/linux-cnc/linuxcnc/configs/sim.axis'
Machine configuration file is 'lathe.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./ethercatlathe.hal
./ethercatlathe.hal:39: Pin 'lcec.0.1.cia-statusword' does not exist
Last edit: 27 Oct 2025 23:56 by hanz24.
28 Oct 2025 01:17 #337324 by rodw
Replied by rodw on topic hal configuration
Your slaves are numbered from 0 so I think you should use lcec.0.0.cia-statusword
  • hanz24
  • Visitor
  • Visitor
28 Oct 2025 01:50 #337327 by hanz24
Replied by hanz24 on topic hal configuration
i already try that too, change the hal into lcec.0.0.cia-statusword but still got the same error. is it because my drive is not detectable using "halcmd show pin lcec" comand? because when i try that there is no result, but its still show up by using ethercat slaves.
28 Oct 2025 02:12 #337329 by Aciera
Replied by Aciera on topic hal configuration
@hanz24, Appologies, your profile got thrown out by accident. Feel free to reregister using your previous login data.
The following user(s) said Thank You: hanz24
31 Oct 2025 17:42 #337609 by nichtAlex
Replied by nichtAlex on topic hal configuration
Can you try removing the "0x" part from the pdo entries in the xml file?
For example
"<pdoEntry idx="6040" subIdx="00" bitLen="16" halPin="cia-controlword" halType="u32"/>"
is working for my A6 servo driver
Time to create page: 0.256 seconds
