Physical buttons to 7i96s+7i77
- Masiwood123
- Thank you received: 93
26 Nov 2025 11:06 - 26 Nov 2025 11:11 #339241
by Masiwood123
Physical buttons to 7i96s+7i77 was created by Masiwood123
..in connection with the machine retrofit #338210
, I would like to include the hardware buttons in the configuration, also calculating the mpg. I have a lot of free inputs (all on 7i96s) and about twenty on 7i77 where I left the first three free as I understood that they are analog because of the potentiometer) now I need a suggestion, since dont have schematic for the old controller and not for the buttons, I think they are all on 24vdc including mpg. the outputs that I connected to 7i77 lit the bulbs of these buttons at 24v. should I try the configuration in terms of the mpg pendant for selector increments and mpg, and for spindle and feed override how should I connect? Thanks
Last edit: 26 Nov 2025 11:11 by Masiwood123.
- Masiwood123
26 Nov 2025 18:35 - 26 Nov 2025 18:37 #339252
by Masiwood123
Replied by Masiwood123 on topic Physical buttons to 7i96s+7i77
2.9.0. I didn't have a 7i92 with me, so I used a 7i96s as the main card, which turned out to be better because I'm planning two additional axes later that will use steppers...now about mpg, maybe and I have an example to try...but I didn't have any experience with connecting potentiometers for feed and spindle override, and any Hal example would be valuable to me.
Last edit: 26 Nov 2025 18:37 by Masiwood123.
- Thank you received: 5334
26 Nov 2025 19:56 #339259
Replied by PCW on topic Physical buttons to 7i96s+7i77
If you search the forum for "MPG" you will find a number of examples
The 7I77 has 2 MPG inputs (4 pins) and the 7I96S has 4 MPG inputs (8 pins)
Either will work wit 5V to 24V signals
The following user(s) said Thank You: Masiwood123
- Masiwood123
26 Nov 2025 20:02 #339261
by Masiwood123
yes, I knew about the 7i96s, yes, I had connected two independent ones when I had a lathe that worked in sync... here I will find an example for one via the axix selector,as a pendant I think it's not a problem. My problem is that I don't know how to connect potentiometers in the hall (if the first three inputs in mode 3 are analog on the 7i77?) how can they recognize it in the hall as spindle override and feed override?
26 Nov 2025 20:27 #339262
I think the tricky part with feed override and spindle speed override
is to get along with the GUI
- COFHAL
- Thank you received: 62
27 Nov 2025 11:01 #339314
by COFHAL
Replied by COFHAL on topic Physical buttons to 7i96s+7i77
Later I'll send you an example; I have two potentiometers connected to a 7i73 to control those parameters, and with a component that saves their position when the LCN is executed.
- Masiwood123
27 Nov 2025 11:59 #339318
by Masiwood123
thank you very much, I really appreciate it
- COFHAL
27 Nov 2025 21:10 - 27 Nov 2025 21:11 #339346
by COFHAL
#SE USAN CON LOS POTENCIMETROS DE OVERRIDE PARA QUE AL ENCENDER LA MAQUINA MUESTRE EL VALOR CORRECTO DE LA POSICION DEL POTENCIOMETRO
loadrt hyst names=hyst.feedpot,hyst.SPDLpot
loadrt mux_generic config=fs2,fs2
addf mux-gen.00 servo-thread
addf mux-gen.01 servo-thread
addf hyst.feedpot servo-thread
addf hyst.SPDLpot servo-thread
# --- OVERRIDE SIGNALS ---
# --- ANULAR VELOCIDAD DE AVANCE Y DEL SPINDLE ---
# ----BIT DIRECT VALUE
setp halui.feed-override.direct-value true
setp halui.spindle.0.override.direct-value true
# ESTABLECER ESCALA DE CAMBIOS DE LA ANULACION DE AVANCE Y SPINDLE
setp halui.feed-override.scale 0.01
setp halui.spindle.0.override.scale 0.01
OVERRIDE AVANCE
setp hyst.feedpot.gain 0.05
setp hyst.feedpot.deadband 0.7
setp hyst.feedpot.step 1
setp mux-gen.00.in-float-00 100
setp scale.1.gain 60.61 # ESCALAR LA ENTRADA ANALOGA DE AVANCE OVERRIDE, VALOR ANALOGO 200/3 VOLTIOS = 60.61
setp mux-gen.00.in-float-00 100 # ESTABLECER EL VALOR DE AVANCE OVERRIDE EN 100% CUANDO SE APAGA LA MAQUINA
net analogin0 scale.1.in <= hm2_7i92.0.7i73.0.0.analogin0
net feedpot-raw scale.1.out
net feedpot-raw hyst.feedpot.in
net feedpot-hyst hyst.feedpot.out mux-gen.00.in-float-01
net machine-is-on mux-gen.00.sel-bit-00
net feedpot-mux mux-gen.00.out-s32 halui.feed-override.counts
FIN OVERRIDE AVANCE
OVERRIDE VELOCIDAD SPINDLE----
setp hyst.SPDLpot.gain 0.05
setp hyst.SPDLpot.deadband 0.7
setp hyst.SPDLpot.step 1
setp scale.2.gain 60.61 # ESCALAR LA ENTRADA ANALOGA DEL SPINDLE OVERRIDE, VALOR ANALOGO 200/3 VOLTIOS = 60.61
setp mux-gen.01.in-float-00 100 # ESTABLECER EL VALOR DE SPINDLE OVERRIDE EN 100% CUANDO SE APAGA LA MAQUINA
net analogin1 scale.2.in <= hm2_7i92.0.7i73.0.0.analogin1
net SPDLpot-raw scale.2.out
net SPDLpot-raw hyst.SPDLpot.in
net SPDLpot-hyst hyst.SPDLpot.out mux-gen.01.in-float-01
net machine-is-on mux-gen.01.sel-bit-00
net SPDLpot-mux mux-gen.01.out-s32 halui.spindle.0.override.counts
OVERRIDE AVANCE
FIN OVERRIDE AVANCE
Last edit: 27 Nov 2025 21:11 by COFHAL.
- Masiwood123
27 Nov 2025 21:27 - 27 Nov 2025 21:28 #339347
by Masiwood123
thank you very much, I will try this tomorrow related to hal file, this is an example for a spindle, I believe it is similar for feed? I also need information on where this file should be located, in which Linux folder ``hist.comp``? and do I need to add any line to the ini, except halfile=...
Last edit: 27 Nov 2025 21:28 by Masiwood123.
- Thank you received: 7490
27 Nov 2025 21:44 #339348
Replied by tommylight on topic Physical buttons to 7i96s+7i77
copy the .comp file to your home folder, open terminal:That will compile and install the file/component where it belongs, then in the hal file there should be the entries pertaining to hyst and it's generated pins as above posted entries from Cofhal
sudo halcompile hyst.comp --install
Time to create page: 0.967 seconds
