Hi together,
I am building a central lubrication system for my machine. The existing ones are mainly based on oil and hard-ways so run on a relatively fast cycle of min/ a few meters. See here
www.forum.linuxcnc.org/49-basic-configur...-lube-time-component
My question is if there is a way to obtain the system date and time to build a function to run the lubrication e.g. once a week?
If there is a way to have the date in HAL I think its easy to build a routine with a written settings parameter of the last execution and and the digital input feedback from the SSV sensor.
