Spindle encoder configuration (with G76 threading command and Mesa 7i96s)
6 months 3 weeks ago - 6 months 3 weeks ago #345287 by slowpoke
is spindle.0.at-speed  true?Also does the index work?Test by (either in halshow or with halcmd -kf)sets spindle-index-enable truewatch  spindle-index-enable in halshowit should go high with the sets command and then low when you rotatethe spindle past the index position.
Some progress, but still not quite there.
The error I was receiving ("Chosen spindle(0) not turning in G76")  when I tried opening my gcode file was occurring because I did not have a M03 (start spindle command), because I start my spindle manually. So now the program opens and runs, just not correctly.
I scoped with an actual scope the index signal as well as the other spindle quadrature signals and they are as expected (not sure on the polarity of the index pulse. It is low for most of a spindle rotation, with a brief blip high once per revolution.The program now runs, however it cuts and retracts in the wrong direction (X wise). It seems that the G76 command thinks more negative X is towards the center of the spindle center line and more positive is out and away from the spindle centreline.Even the graphic, shows -X towards the centerline ie. a deeper cut is more negative X), please see attached. Interestingly the animated graphic, shows the correct motion with a slow cut to the left then retracting out for the non-cutting return  Z movement in the real world -X direction (labeled as positive X in the graphic), and then cutting progressively deeper (real world X, graphic more negative X) on each pass..ngc file is as follows:
(huge 1.25 x 7 coarse external thread)
S100 M3
G90
G0 x-0.002 Z0.1G76 P0.1429 Z-1.0 I-0.0876 J0.005 K 0.0876G0 X -0.05 Z 0.1
M5
M30
Answers to your questions:
1) is spindle.0.at-speed  true?  Yes because it's hard set in HAL  (sets spindle-at-speed true)
2) Also does the index work? Yes, it is low for most of the revolution, and blips high momentarily as the magnet passes,See scope capture.
3) set spindle-index-enable true watch  spindle-index-enable in halshow it should go high with the sets command and then low when you rotate the spindle past the index position.  It does exactly that.
I think at this point I just need to resolve the backwards X movement.
I also noticed that when I use the cursor keys to jog the X-axis, they are backwards for the X-axis. Up arrow moved the cross slide down and visa versa.
If I flip the polarity of the X scale value in the ini file, the cursor keys are correct, but the actual cross slide move backwards.
Same thing if I flip the direction of rotation in the servo software, I can get the cursor keys correct, but the actual direction is backwards.
As expected flipping both gets me back to where I started.
I'm not sure if the backwards cursor keys have any correlation with the G76 working backwards for X but seems like there might be a link?
If I change the sign of the "I" term from negative to positive (which should change from external to internal thread mode), the program correctly cuts the thread, The graphic representation in axis shows an internal thread being cut, but the actual action is external resulting in a perfect thread.
Last edit: 6 months 3 weeks ago by slowpoke.
Time to create page: 0.099 seconds
