Spindle encoder configuration (with G76 threading command and Mesa 7i96s)
05 Apr 2026 12:35 - 05 Apr 2026 12:37 #345197 by slowpoke
I have a 600PPR quadrature encoder linked to my spindle with a 3:1 ratio, so 7200 PPR @ mesa spindle encoder input. A & B quadrature signals only, no 1PPR signal, but I don't think I need the 1PPR signal.
In Halshow
 - spindle.0.revs counts up as expected
 - spindle.0.speed-in appears correct
 - spindle.0.index-enable is disabled
in my SM-10.hal file I have:
net spindle-index-enable      <=>  spindle.0.index-enable
IF I comment out this line, I can then enable spindle.0.index-enable manually in Halshow
Regardless when I try to open my 2 line G76 program I get the following error:
"Chosen spindle(0) not turning in G76"
I'm not sure if this is a HAL configuration issue or perhaps I need to do something in the gcode prior to the G76 command, not sure?
I have attached files for clarity.
Thanks,
Jeff
Last edit: 05 Apr 2026 12:37 by slowpoke.
05 Apr 2026 14:53 #345200 by PCW
For threading, you need a 1PPR signal (index) from the spindle.
05 Apr 2026 18:24 #345204 by slowpoke
Before I swap out my present encoder that only has A & B 600 PPR quadrature signals with another one I have that has the A & B, as well as a 1 PPR signal. Is there any trickery in HAL I can do to use spindle,0,revs, that presently counts up 1 every spindle revolution, noting that spindle,0,revs is a float type value, so it slowly ramps up incrementally each revolution before it flips it's integer type digit.
05 Apr 2026 18:44 #345205 by PCW
Is the encoder on the spindle?
if not, the encoder index is not directly usable.
A single proximity/Hall switch on the spindle
could be added if this is the situation
It may be possible to use the spindle position
and some hal logic to simulate index operation
but it would not work well at higher speeds.
 and would forget position between LinuxCNC
runs,
The following user(s) said Thank You: slowpoke
05 Apr 2026 18:51 - 05 Apr 2026 18:57 #345206 by slowpoke
runs,
I'm swapping in my other encoder, that has a 1 pulse per rev signal. The encoder is linked to the spindle with a timing belt, however there is a 3:1 ratio in the timing gears. So I will get 3 pulses per rev, is there a way to divide the Z count by 3 in Hal?
If necessary, I can fit an additional sensor for actual 1PPR
Last edit: 05 Apr 2026 18:57 by slowpoke.
05 Apr 2026 19:18 #345208 by PCW
Its possible but awkward and complex
(because you need to hijack the index detection/enable hardware to count the (very short) index pulses)
Easiest thing  would be to add would be to add a 1PPR sensor on the spindle for index
Even better would be to add a 1 PPR sensor with a wide enough pulse that you could use
it as index mask (retaining the high precision of the encoder index)
05 Apr 2026 19:39 #345209 by slowpoke
Okay, I'm printing a mount for a 1PPR right at the spindle. Please elaborate on the length required for the masking you describe. I could possibly stretch the short pulse .
05 Apr 2026 20:02 #345210 by PCW
If you use a hall sensor as index mask, it will likely be wide enough as is,
but the wider (in degrees) , the easier to setup (because the
encoder index must happen within the 1 PPR signal)
If the 1PPR sensor is used for index directly, its width does not
matter.
05 Apr 2026 20:17 - 06 Apr 2026 15:40 #345211 by slowpoke
matter.
I now have a 1PPR spindle index signal connected and working (using a Hall sensor).
Seems very likely the index pulse will be long enough because there will be 7200 quadrature pulses for every index pulse so every 1/20 of a degree.
Next up figure out what I need to do in HAL to use the index pulse, so I stop getting  "Chosen spindle(0) not turning in G76"
Any help is much appreciated.
Last edit: 06 Apr 2026 15:40 by slowpoke.
06 Apr 2026 17:03 #345233 by PCW
If you have the index connected to the 7I96S index input, then a standard
pncconf or MesaCT created hal file will have the correct connections.
Time to create page: 0.111 seconds
