HAL component for tangential knife
21 Apr 2026 22:41 #345822 by bedouno
Replied by bedouno on topic HAL component for tangential knife
dear sir i spent the last days trying to improve my understanding to linuxcnc system and structure , i hope to give hand and i suggest this proposal " what if we do the tangent calculation in parallel interpreter and syncronize the data somehow whith index ", i am not sure if it is the best practice but i am tring
23 Apr 2026 21:09 #345891 by rodw
Replied by rodw on topic HAL component for tangential knife
Having looked at this a few times, I think that the best place to do it is actually in a G-code filter. ie calculate the heading from the G-code and insert / append C axis moves as appropriate.
Actually, there is a use case that needs motion pins. A plasma cutter cutting bevels. An additional joint is needed to tilt the torch and there are complicated tilting torch holders that keep the torch tip axial to the Z axis (single axis bevel head). I was just chatting to a user with one who uses the post processor approach.
But picture a simpler torch holder design where the torch tip position moves when tilted. A component could take the bevel angle and calculate the offset x,y,z positions of the tilted torch tip and then apply external offsets to locate the torch on the cut path in real time. This way, the machine could consume simple 2D x,y gcode (which is the norm for plasma cutters) and enter plasma cutting nirvana with bevelled holes.
24 Apr 2026 11:59 #345894 by rodw
This appeares to be working now
checkout  the state-tags-arc from my repo to test
github.com/rodw-au/linuxcnc/tree/state-tags-arcs
There is some house keeping to sort out. I need to work out how to use equate G_1,G_2  etc in motion (control.c) I remember the devs last time I tried, they did not like this  but I have not got a solution yet. Its just housekeeping and will only be an issue ig the equates for gcodes are ever changed.
25 Apr 2026 22:30 #345927 by bedouno
"Great work, Rod! This looks like a monumental step forward for LinuxCNC.
I believe this branch is the perfect strategy for implementation. It elegantly solves the real-time synchronization issues that have hindered advanced tangential control in the past.
For my part, I have an assignment to study this implementation . You have indeed laid a cornerstone for the system, and I am very excited to leverage your work for this project.
If I may add my opinion: I fully support your point of view regarding the modifications of G_1, G_2, G_3 equates in control.c. I understand the devs' concerns about real-time sanctity, but your approach to code readability (housekeeping) is crucial for the long-term maintainability of such complex code. Finding that balance is the key.
Thank you again for your incredible contribution."
25 Apr 2026 23:27 #345931 by rodw
We are not out of the woods yet. When I pushed this back to my GitHub, it failed some of the gcode tests.
github.com/rodw-au/linuxcnc/actions
I kind of know what's going on. I just need time to get to make some changes. Just need to add stuff to reset functions.
02 May 2026 22:00 #346118 by rodw
Finally, I have sent a PR to Linuxcnc on Github for this
github.com/LinuxCNC/linuxcnc/pull/3995
It was a lot harder than I thought. Many thanks to grandixximo for his help ensuring all the runtime tests passed.
The following user(s) said Thank You: NWE
07 May 2026 01:11 #346230 by bedouno
great work , i hope it will be included in the comming version
07 May 2026 01:51 #346234 by rodw
I'm working on it again today to  ensure it works on XZ and YZ planes and also to prevent a helix being treated as a circle. None of this has any impact on your use case.
07 May 2026 03:14 #346236 by tommylight
07 May 2026 03:14 - 07 May 2026 03:32 #346237 by bedouno
can you please refer to the implementation of it and how to use it and configure the z lift angle and z height , or a demo component of the usage like the Mach3 Implementation
Last edit: 07 May 2026 03:32 by bedouno.
Time to create page: 0.151 seconds
