building my first Hal component
- garymcrobertpdx
05 Jan 2011 01:43 #6418
by garymcrobertpdx
building my first Hal component was created by garymcrobertpdx
I am attempting to build my first Hal component
I have consulted the docs at
linuxcnc.org/docs/html/hal_comp.html#r1_14
I copied the arraydemo code and placed it in a file
named componet-arraydemo
I looked for emc2/src/hal/components but the
/src/hal/components did not exist so I created
the directory structure and placed the file
componet-arraydemo into it.
I opened a terminal and entered the command line
comp --install component-arraydemo.comp
this is was the response it appears nothing happend
me@CNC:~$ comp --compile co,ponent-arraydemo.comp
The program 'comp' can be found in the following packages:
* nmh
* mailutils-mh
Try: sudo apt-get install <selected package>
bash: comp: command not found
me@CNC:~$
I tried several variations on the command line
but faild to get results. An explicit example of how
to make this process work would be very helpful
* nmh
* mailutils-mh
me@CNC:~$
- garymcrobertpdx
05 Jan 2011 06:13 #6419
by garymcrobertpdx
Replied by garymcrobertpdx on topic Re:building my first Hal component
OK figured out that I had to down load and install emc2-dev
Now comp seems to be working but it gives me an error
“Unrecognized file type for mode preprocess “ don’t
know what this exactly means. Could still use a guiding
hand with learning how to do this.
- Thank you received: 4994
05 Jan 2011 10:02 #6420
Replied by andypugh on topic Re:building my first Hal component
How did you download it?
sudo apt-get install emc2-dev
should install all required packages. I assume, though, that this is what you did.
You shouldn't actually need to create the src/hal/components tree, I think you can put the .comp file anywhere you want.
Did the error message you posted happen with comp --install foo.comp ? I can imagine you would get that message trying to comp the wrong file (you will, at various points, create a foo.c, foo.o and foo.ko file, and pointing comp at some of these might give the reported error.
- BigJohnT
- Thank you received: 1176
05 Jan 2011 12:59 #6430
by BigJohnT
Replied by BigJohnT on topic Re:building my first Hal component
When I built a comp I just put the comp file with the other components in emc2-dev/src/hal/components then built EMC2 following these instructions
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Ins...ilding_emc2_realtime
then looked at my errors in the terminal window... usually syntax errors for me.
- garymcrobertpdx
05 Jan 2011 20:07 #6452
by garymcrobertpdx
I found a post here by someone that was experiencing the same problem
And fallowed the instructions he received.
Used ubuntu's system > software sources & the synaptic package manager
to locate and install emc2-div this appeared to work.
According to the comp docs there are several ways to use comp and some
limitations. I tried several combos hoping to stumble onto the correct
arrangement.
The error message was produced on my first attempts at comp. Currently
the error message I receive is “IOError: [Errno 2] No such file or directory:
arraydemo.c “
I have tried tweaking the file name extension and moving the file to several
different directories with no success.
I searched for the directory structure emc2-div/src/hal/components and failed
to find any thing like it. Perhaps comp is not installed after all????
Being a Linux newbie tends to compound these difficulties.
arrangement.
arraydemo.c “
- BigJohnT
05 Jan 2011 23:34 #6455
by BigJohnT
Ok, I'm assuming you have the installed version of EMC2. If so follow the instructions here
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Installing_EMC2
to download a git copy of the development version or a branch and build it. I'm not sure what you found with the Synaptic Package Manger but that is the wrong way. The files will be installed in your home directory.
- garymcrobertpdx
06 Jan 2011 01:31 #6461
by garymcrobertpdx
YES thats what I was in need of, things look more like they should,
now I think I have a chance of making a component.
But as Yogi Berra said "it ain't over till its over"
Many thanks
Many thanks
- garymcrobertpdx
06 Jan 2011 07:00 #6467
by garymcrobertpdx
Still getting no where with this. Tried comp with an existing comp file got the same errors
me@CNC:~$ comp biquad.comp
File "/usr/bin/comp", line 1297, in <module>
main()
File "/usr/bin/comp", line 1266, in main
process(f, mode, outfile)
File "/usr/bin/comp", line 1140, in process
a, b = parse(filename)
File "/usr/bin/comp", line 386, in parse
f = open(filename).read()
IOError: [Errno 2] No such file or directory: 'biquad.comp'
me@CNC:~$ comp --install biquad.comp
main()
me@CNC:~$
What am i doing wrong????
main()
main()
me@CNC:~$
06 Jan 2011 10:03 #6470
You possibly need to give comp the full path to the .comp file (or possibly issue the comp instruction from within that directory)
- garymcrobertpdx
07 Jan 2011 04:17 #6499
by garymcrobertpdx
OK I have successfully got comp to convert a comp into a c program
not sure if I have seceded in creating a real time component yet.
I will test this soon.
A question since I am writing C code can I do any thing C or are
there significant restrictions. For example can I open a disk file
and read data into an array in my C code which this ultimately
happens in the hal component when it executes,
Again thanks for the patient assistance.
