- Configuring LinuxCNC
- Advanced Configuration
- ClassicLadder
- Classicladder, Modbus and read values of a servo motor
- MATZE-ATZE-SCH
- Thank you received: 6
30 Jan 2019 20:02 #125327
by MATZE-ATZE-SCH
Classicladder, Modbus and read values of a servo motor was created by MATZE-ATZE-SCH
Hello.
I want to read out a servo controller to display the load of the axis in Linuxcnc.
The Controller is connected via Modbus in CL and the connection works.
So i read out the adress 1546. The Servo will output a value between -100 - +100 in HEX.
So the Values from 0-100 are working fine, but if the controller puts anything out with a -,
then i get in the CL values in the range of 65535.
How can I set it up, that the value is always positiv?
Best regards
Marcel
Best regards
Marcel
- Grotius
- Thank you received: 2349
30 Jan 2019 20:22 #125330
by Grotius
Replied by Grotius on topic Classicladder, Modbus and read values of a servo motor
HEX <-> BINARY <-> SIGN
0-7 <-> 0000-0111 <-> pos
8-F <-> 1000-1111 <-> neg
Negative value's cannot be shown positive, unless you add a formula *-1
- MATZE-ATZE-SCH
30 Jan 2019 21:08 #125342
by MATZE-ATZE-SCH
Replied by MATZE-ATZE-SCH on topic Classicladder, Modbus and read values of a servo motor
Hello,
If i define the value to be absolute, then it would be only positiv, right?
With a formula *-1, then my positiv values would become negativ?
Best regards
Marcel
What do you mean with this?HEX <-> BINARY <-> SIGN
Best regards
Marcel
- MATZE-ATZE-SCH
06 Feb 2019 22:40 #125887
by MATZE-ATZE-SCH
OK,
i´ve got it to work:
I first compare the input value from %Q0, if the input value is <2000, then i output the value on %QW1.
So I have the Imput from 0-100 on %Q0 -> 0-100 on %QW1.
With a nother comparisson I check if the value from %Q0 is > 2001.
If this is true, a use a assignment: %QW1=65535-%Q0.
So when the servo puts out -10, on %Q0 I have a value of 65525.
And 65535-35525=10, so I have on %QW1=10.
Now I have tried to run classicladder without the gui,
so I have written in the .hal:
loadusr classicladder --modbus --nogui myladder.clp .
But the CL doesn´t load, it only loads without the --nogui in the .hal...
What have I wrong?
Best regards
Marcel
What have I wrong?
Best regards
Marcel
- Thank you received: 2181
07 Feb 2019 00:42 #125898
Replied by cmorley on topic Classicladder, Modbus and read values of a servo motor
Modbus requires the gui to run.
Use the HAL pin hidegui (something like that) to hide the gui
Also I am pretty sure CL has an absolute command:
linuxcnc.org/docs/devel/html/ladder/clas...ladder.html#_compare
Might do what you want.
Chris M
Chris M
- MATZE-ATZE-SCH
07 Feb 2019 08:56 #125911
by MATZE-ATZE-SCH
Ok,i will later look at this.
With ABS I had no sucess. But I think it is a error of the servo, who send wrong numbers. Have read out the servo with another modbus programm, it also shows , that for example the servo should output -10, I get a value of 5525 on modbus.
- Mike_Eitel
- Thank you received: 183
07 Feb 2019 17:13 #125933
by Mike_Eitel
Replied by Mike_Eitel on topic Classicladder, Modbus and read values of a servo motor
Are the two bytes inverted?
Means high and low bytes inverted?
- MATZE-ATZE-SCH
07 Feb 2019 18:52 #125940
by MATZE-ATZE-SCH
Hello,
two bytes inverted?
The Servo response from high to low, if this is what you mean?
Best regards
Marcel
two bytes inverted?
Best regards
Marcel
- Thank you received: 4154
07 Feb 2019 19:43 #125947
I think Mike means the hardware could store numbers in a high byte,low byte order when the PC is low byte, high byte order.
If that is the case in hexadecimal numbers for decimal 10 (forget the sign for now)
low byte 000A 0000 becomes high byte 0000 000A which is several magnitudes of order larger!
Replied by rodw on topic Classicladder, Modbus and read values of a servo motor
Hello,
two bytes inverted?
Best regards
Marcel
- MATZE-ATZE-SCH
08 Feb 2019 17:04 #126011
by MATZE-ATZE-SCH
OK,
but I don think that is the error.
If this will be the case, the values would only be offset, right?
But if I look at the Servo drive,
if there is -1, the value in Modbus is 65536,
if there is -10, the value in Modbus is 65526 etc.
So it is going only in the wrong direction.
In the manual of the servo it is high bit low bit.
But what a order expect Classicladder?
Best regards
Marcel
Best regards
Marcel
- ClassicLadder
Time to create page: 1.526 seconds
