[Solved] Classic Lader doesn't run E-stop
  • aleksamc
  • aleksamc's Avatar Topic Author
  • Platinum Member
  • Platinum Member
02 Feb 2021 08:40 - 03 Feb 2021 10:16 #197390 by aleksamc
In the postgui.hal I connected such pin:
net estop-ext classicladder.0.out-00 =>  iocontrol.0.emc-enable-in
But when out-00 is TRUE, machine is disabled.
Why I don't understand. I'm only move pin from hardware input to classiclader output.
File Name: custom_2021-02-02.hal
File Size:2 KB
File Name: my_cnc_2021-02-02.hal
File Size:11 KB
File Name: postgui.hal
File Size:1 KB
Last edit: 03 Feb 2021 10:16 by aleksamc.
  • aleksamc
  • Platinum Member
  • Platinum Member
03 Feb 2021 08:58 #197526 by aleksamc
Replied by aleksamc on topic Classic Lader doesn't run E-stop
Nevertheless of emc-enable-in is true,
iocontrol.0.user-enable-out is FALSE.
What make iocontrol be deactivated?
  • aleksamc
  • Platinum Member
  • Platinum Member
03 Feb 2021 10:14 - 03 Feb 2021 10:15 #197536 by aleksamc
problem was solved. Answer is here
Last edit: 03 Feb 2021 10:15 by aleksamc.
The following user(s) said Thank You: Soccer Kid
Time to create page: 0.167 seconds
