ClassicLadder named input
4 years 9 months ago #231689 by bkt
ClassicLadder named input was created by bkt
he because completely new on classicladder i run my example using some tutorial ... all good I connect in/out with EL1008/2008 ...
these my ladder-glue.hal file (only first row):
# first load realtime portion of classicladder, and create a 1ms loadrt classicladder_rt period=1000000 # hook functions to realtime thread addf classicladder.0.refresh classicladder.thread 1 # create some I/O signals # connect I/O signals to classicladder net I0 => classicladder.0.in-00 net I1 => classicladder.0.in-01 ...... #30 in 20 out at least
Question: is possible to use "pressulre-low" for example instead "I0"?? .... because I try with error .... seems not possible but I ask to classic ladder expert .....
Plus I have an annoing warning about error on period 0 of 50.000ns .... but I run all on rt-preempt system so no one use base period ... only servo period instead ... where become these warning? My ini file is without BASE_PERIOD .... need to used because classicladder? I can put it on 100.000 .... so system can be happy.
4 years 9 months ago #231697 by BigJohnT
Replied by BigJohnT on topic ClassicLadder named input
The signal name can be almost anything unique.
This is a perfectly legal net line.
net pressure-low => classicladder.0.in-00
Always put the exact error in the message or if long attach as a text file.
JT
The following user(s) said Thank You: bkt
4 years 9 months ago #231703 by bkt
Replied by bkt on topic ClassicLadder named input
I means inside classic ladder in graphica ladder gui programming ( -| |- or -|\|- not able named "mary" instead %I0 ..... for example).
AZny how tomorrow try again and take a screenshot ....
4 years 9 months ago - 4 years 9 months ago #231740 by bkt
These appear when try to insert "in2" intead %I12 .... in my .hal file I write these that is perfectly legal obviusly
net in2 <= lcec.0.1.din-2 net in3 <= lcec.0.1.din-3 net in4 <= lcec.0.1.din-4 net in5 <= lcec.0.1.din-5 net in6 <= lcec.0.1.din-6 net in7 <= lcec.0.1.din-7 net in2 => classicladder.0.in-12 net in3 => classicladder.0.in-13 net in4 => classicladder.0.in-14 net in5 => classicladder.0.in-15 net in6 => classicladder.0.in-16 net in7 => classicladder.0.in-17
Last edit: 4 years 9 months ago by bkt.
4 years 9 months ago #231816 by BigJohnT
Check Display symbols and create your symbol names for each variable with the Symbols button.
JT
4 years 9 months ago #232109 by bkt
On Dysplay Simbols can see name assigned from .hal file .... thanks ... but not possible assign a arbitrary name on new var .... so think is possible to assign only if not included in some manner on some .hal file .... or when total virgin program is created. Not try but seems to me is right .... you can confirm or not?
Maybe I misunderstood.
bkt
Time to create page: 0.536 seconds
