Classic Ladder not working with LinuxCNC Rio
20 Nov 2024 00:03 - 20 Nov 2024 00:06 #314884 by mBender
Hi Forum,
I am trying to get Classic Ladder working with ]LinuxCNC RIO.
I try to get my VFD working with Classic Ladder. This is what works on the same machine with soft stepping.
loadrt classicladder_rt numS32out=100
addf classicladder.0.refresh servo-thread
loadusr classicladder --modmaster vfd.clp
When I start LinuxCNC with the FPGA connected I get the following error:Shared memory conflict or RT component not loaded!
ERROR CLASSICLADDER-   Ladder memory allocation error
I tried to remove the numS32out=100, but no success. I can load the program manually with the ladder editor, but it is still not in modmaster mode and won't work.
Someone an idea what the cause would be and how to fix it?
Last edit: 20 Nov 2024 00:06 by mBender.
21 Nov 2024 08:43 #314971 by Aciera
Not sure if this applies to your setup but classicladder does not seem to work with [HAL] TWOPASS = on
21 Nov 2024 18:22 #314988 by spumco
Classic ladder works on both my machines with TWOPASS = ON
2.9.3 on mill, and 2.10 on lathe.
Maybe the loadusr line needs to be in postgui.hal?
22 Nov 2024 14:44 #315035 by mBender
Replied by mBender on topic Classic Ladder not working with LinuxCNC Rio
Indeed Twopass was on. I switched it off. This lead to the following behavior:
The machine started classic Ladder. CL worked as intended. The Axis Gui of the CNC did not load. When I closed CL, the axis gui loaded. I thought I could go into the Ladder Editor and simply start it again, but once I was in ladder editor, the Modbus Maser pages in the config where not there. Like it was just loading a blank program.
I have not tried to put the CL part in the postgui hal file. Will try that.
22 Nov 2024 22:33 #315064 by mBender
I tried putting the loadusr line in the posthui hal file. Did not work. I tried to put all 3 lines in the postgui hal file, did not work either.
The problem is, even in the postgui hal file, CL opens up, but the Axis GUI of the machine does not open up, until I quit the CL.
I feel like the solution is very close, I just don't know how to set up the starting sequence.
24 Nov 2024 01:48 #315152 by spumco
OP-
First thing to do is run LCNC from the command line, and turn on some level of debugging in the INI file.  That's helped me catch 'backstage' problems, or at least I can figure out where to start looking.
Then run LCNC - with and without twopass - and see what is happening in the terminal window.
I suggest changing the terminal preferences to 'unlimited scroll-back' before you start.
Once you capture a problem ion the terminal, take a screenshot and post it up here.
26 Nov 2024 01:04 #315265 by mBender
Will do that once back from Thanksgiving holidays.
03 Dec 2024 02:39 #315853 by mBender
I have some logs created. In the logs you find the different rio.hal and rio.ini configurations.
Twopass disabled
loadusr -w classicladder --modmaster vfd.clp in postgui_call_list.hal
pastebin.com/61urYP3n
Twopass enabled
pastebin.com/bKd8N5Ex
03 Dec 2024 06:47 - 03 Dec 2024 06:57 #315859 by Mecanix
Replied by Mecanix on topic Classic Ladder not working with LinuxCNC Rio
Lcnc, Rio, Modbus all looking good. GTK not so much though (Failed to load module "atk-bridge").
Are you on a VM or accessing your linux session via VNC or XRDP by any chance? Additionally, it would be a proactive move to list/describe all the GTK debugging steps undertaken so far so that others seeing this can be updated on your progress. Bet it's an easy fix.
Last edit: 03 Dec 2024 06:57 by Mecanix.
03 Dec 2024 13:42 #315885 by Aciera
Re: Failed to load module "atk-bridge"
Not sure how relevant that error message is but according to this
dev1galaxy.org/viewtopic.php?id=1815
you could maybe try:
sudo apt install libatk-adaptor
Time to create page: 1.475 seconds
