Einar wrote: My theory was that this axis is partly disconnected from the guts of LinuxCNC. And by giving feedback through axis.3.motor-pos-fb without honoring the axis.3.motor-pos-cmd there must be an increasing discrepancy inside the motion software.
ArcEye wrote:The hal line
net apos-fb stepgen.3.position-fb => axis.3.motor-pos-fb
has to be commented out or you will get following errors.
Because axis.3.motor-pos-cmd is not connected to anything it will be 0. Therefore it will see any value other than 0 in axis.3.motor-pos-fb as an error
Now I need to be able to jog the ATC so I can back it up against a pawl thus homeing it.
This ATC have a sensor. I hope this can be used to home the ATC.
BTW: Is there a better way to put the file resulting from compilation of a comp than manual copy to my user lib Directory?
As the toolpost is back mounted it will need to cut away from the spindle.
One thing I need to figure out is the lead in move
