ArcEye wrote: OK, we have been a cross purposes.
Until now, you have not actually said that you have an ATC complete with original motor AND a Nema 17 stepper.
I could not work out why you were taking so much interest in a board to operate a motor you didn't have.
ArcEye wrote: So long as you have details of what the inputs and outputs do, it will be possible to control it with linuxcnc.
I am surprised there are no sensors and it would no be beyond the wit of man to add at least one, to mark Tool 1 position at least.
But worst case scenario would be that the operator tells the component what the current tool is at startup and it can work out the rest from there.
It looks like it would be easy to also add a proximity sensor to detect the pawl position, which would be much better than a simple time-delay.ArcEye wrote: But worst case scenario would be that the operator tells the component what the current tool is at startup and it can work out the rest from there.
