thanks for modifying the PP for LinuxCNC/F360. I haven't use the code on my Lathe yet but that's coming. I noticed that I am getting error "ReferenceError: nFormat is not defined" when I enable showSequenceNumbers. It works fine without it.
I looked at the code but still need to learn how to modify it and it might be an easy fix for you. Not super important but sometimes useful to have sequence numbers.
My hat is off to you Robban as I continue my with Linuxcnc stuff earlier this year we bought our Mesa board and have been able to make somethings work which has been a big milestone but like everything else there was still some road blocks and one biggie is a post processor a lathe until I came across your post so what the heck just as of yesterday well what do I have to loose so I downloaded your zip file mind you I will be the first person to say I do not no what I'm doing when it comes to software but over time I might get things working just like what happen yesterday so once downloaded and Fusion open we created a tool path of a small part and then processed to post to but once in that screen we pull down the menu from and selected Tormach post open config and copy the zip file and replace what was there and then edit the file extension with .ngc and bingo finish save and then load file into Axis and Gmoccapy and it loaded WOO a huge step has been made so now was to see if it will run but (not) just had to delete the T0101 and tried again and it worked, is there still to improve hell yes but this is a start some days things don't work and weeks are spent trying to figure it out and other days it all falls into place just like if I no what I'm doing.
