Boxford 250F options?
8 years 8 months ago #106704 by Ross77
Replied by Ross77 on topic Boxford 250F options?
I did try but nothing came up except people selling the same or similar.
model is A20B-1002-0730/02A
8 years 8 months ago #106706 by Todd Zuercher
Replied by Todd Zuercher on topic Boxford 250F options?
I think part of your problem finding any info, is that part number isn't the part number for the servo drive, it is one component of the servo drive. I think the sticker with the drive part number should be somewhere on the side of the metal frame that that board is mounted to, and should start with A06B-.
8 years 8 months ago #106708 by Todd Zuercher
Over here I think.
The following user(s) said Thank You: Ross77
8 years 7 months ago #107927 by Ross77
Just got the machine back from a friends lock up so I have finally been able to check the motor drives. They are A06B 6058-H002.
I still cant find much info, some seem to run off 240v and just use the second phase to boost the power when needed.
So if they can run off 240v is it a simple case of tapping into the 10v control line?
8 years 7 months ago #107929 by andypugh
Replied by andypugh on topic Boxford 250F options?
It might be that simple. You can experiment with a 1.5V battery.
8 years 6 months ago #109835 by Ross77
Spent a bit of time on this again today and it does look like the AC servo drives are 240V but they still need a 3 phase supply.
Looking at similar manuals the drive should have a 3 phase supply for the power to feed the motor and a single phase contol feed that can be linked to the Estop.
I think the rest of the machine can easily be rewired for single phase but the servo drives could be the stumbling block. are these drives like a vfd and can take a single phase supply but needs to be derated?
Ive also noticed that the encoders go to a separate controller so not sure if it is possible to hack into the contol side.
Time to create page: 0.236 seconds
