Cayenne wrote: Sounds like my problem!
If my machine has no limit or home switches and no tool changer why do we need to home the axis?
If this is a lathe, then typically the tool length offset of any tool is relative to the length of a probe or another tool. All my tool lengths are relative to my Tool 1 (turning and facing) tool. I jog to the material end, touch-off G54 to zero, and take a facing cut at Z=0 with tool 1. Then take a test cut to a diameter with the same tool and set that as the G54 X offset. Then I can change tools to (for example) a threading tool and the diameter and length are correct.I am using a manual quick change tool post.
what would a tool length offset be relative to???
now it's just mathematical insanity where nothing is reproducible. even the inputs for touchoff, and tool touchoff seem to randomly prefer radius or diameter. Can someone please point me to a current startup work flow for turning?
Cayenne wrote: When I first start LinuxCNC the "touch off" obeys the radius mode input.
The "tool touch off" wants diameter inputs and later, it wants radius inputs (bug?) maybe I'm not understanding things.
How do we zero out all offsets?? because ounce I enter the wrong tool g54 offset, no matter what I do i can never zero out the g54 in order to start over.
The radius in the tool table doesn't matter unless G41 / G42 are active. and Fusion CAM does not use those.I have been using F360 for toolpaths, which compensates for tool tip radi (i believe) so should i enter a tool tip radius in LCNC tool table?
