old cnc lathe retrofit
- vre
- Thank you received: 17
04 May 2019 05:24 - 04 May 2019 06:25 #132695
by vre
old cnc lathe retrofit was created by vre
Hello.
I found an old cnc lathe with bad electronics (Fanuc 5T control) to retrofit it with linuxcnc like this
www.veda-bg.com/pictures/CP%20586.2.JPG
www.veda-bg.com/pictures/CP586.1.JPG
www.veda-bg.com/pictures/CP586.3.JPG
The main spindle is 3 phase induction motor 25kw
Can i use it with encoder and inverter as C axis with live tooling?
Is possible to change ways with linear rails in a machine of that size?
What extra axis can add because now is standar 2 axis lathe?
How can control tool turret from linuxcnc with classiclader ?
A machine of that size (total machine weight is 5tons)
how many kw servomotors need for Z & X axis ?
Last edit: 04 May 2019 06:25 by vre.
- Thank you received: 1476
04 May 2019 13:45 #132736
Replied by Todd Zuercher on topic old cnc lathe retrofit
The original servos are probably simple brushed DC servo amps that should be easy to control with Linuxcnc.
Induction motors generally don't lend themselves to being used as servos. You may need to replace that and modify the drivetrain to use the spindle as a c axis.
Not sure about adding profile ways. Sounds like a very big job to do right. On the order of building your own machine from scratch.
04 May 2019 18:44 #132760
Replied by andypugh on topic old cnc lathe retrofit
Apparently the DMG lathes with a C axis have a pneumatically engaged worm gear for indexing operations. This is probably the best way to get stiff control.
- vre
05 May 2019 13:31 #132833
by vre
Replied by vre on topic old cnc lathe retrofit
Do you have a photo/video to understand how this system works?
- pl7i92
- Thank you received: 358
05 May 2019 13:53 #132836
by pl7i92
Replied by pl7i92 on topic old cnc lathe retrofit
this older controles are not the best way to start a Retrofit as they got not the modern style builds and you spend money you better invest in newer technologie
- JR1050
- Thank you received: 31
06 May 2019 04:51 - 06 May 2019 04:52 #132916
by JR1050
Replied by JR1050 on topic old cnc lathe retrofit
Machines with Fanuc 5 controls would be 1977-1980. The servo motors will be black cap dc, the larger ones made by Gettys, drives will more then likely be scr, not transistor. They are rugged, but not fast, they also don't have tachs, the Fanuc control generated the analog tach signal for the drive, you must provide a tach signal to the drive or it will run away. As far as I know, this has been accomplished in LCNC. Encoders 0n black cap motors were usually 1024 cpr.
Most machines of that era used dc spindle motors with a dc drive and contactors for forward and reverse. I would double check, as far as I know , Ac drive technology was still a few years away. My guess is you probably have either a Fuji or Mitsubishi dc drive and motor . The first Fanuc AC spindle motors and drive showed up on the 6TB/6MB , these machines usually had yellow cap dc motors.
With a front and rear turret, the front turret will be X+ programming, the rear will be X- with G2 and G3 reversed.
There have been several similar type Mazak lathes from that era done with Lcnc , maybe one of the owners could lend some insight.
Last edit: 06 May 2019 04:52 by JR1050.
- vre
06 May 2019 20:38 - 07 May 2019 17:32 #132997
by vre
Machine is from 1981.
This is the label from the machine.
The spindle motor is brushed dc can i drive it with this igbt module via pwm?
www.semikron.com/products/product-classe...gd126d-23916110.html
(i have already this module)
This the spindle motor that has the machine
www.ebay.com/p/FANUC-A06b-0813-b002-Spin...achometer/1919231280
Last edit: 07 May 2019 17:32 by vre.
- vre
31 May 2019 13:20 #135467
by vre
Hello again.
Machine has 2 servo drives like these
www.ebay.com/itm/Fanuc-Fujitsu-Velocity-...RRANTY-/202004216333
How can i drive these drives?
31 May 2019 13:44 #135468
Probably analogue voltage velocity command, so you are looking at
Pico PPMC
General Mechatronics
or the
Mesa 7i77
(Though there are a few other options too: wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_Supported_Hardware
- RotarySMP
- Thank you received: 595
03 Jun 2019 13:15 #135745
by RotarySMP
Replied by RotarySMP on topic old cnc lathe retrofit
It looks like this machine has never been used beyond one test cut. Why would you want to fit linear rails if the original slide ways are straight and unworn?
Mark
Mark
Moderators: piasdom
Time to create page: 0.780 seconds
