Need help setting up a lathe(Sherline)
- kbec
- Thank you received: 4
17 Nov 2019 19:56 #150540
by kbec
Replied by kbec on topic Need help setting up a lathe(Sherline)
They have the harness, they are a little more expensive though.
- Leon82
- Thank you received: 79
17 Nov 2019 20:02 - 17 Nov 2019 20:06 #150542
by Leon82
Replied by Leon82 on topic Need help setting up a lathe(Sherline)
You will be wiring from the driver to the windings in the motor. Having a connection like that will make it easy to unplug to work manually.
But if the other side is only sold with the control box you may need to get a different set.
I found a pack of 10 on Amazon for cheap. 4 pins and they have a screw retaining ring
Aviation Plug Connector 10 Pairs Male Female Panel Metal Wire Connector 16mm Socket (4 Pins 10-Pack) www.amazon.com/dp/B07D7SHKGK/ref=cm_sw_r_cp_apa_i_mFA0Db2HXPG6K
Last edit: 17 Nov 2019 20:06 by Leon82.
22 Nov 2019 13:00 #150908
Replied by andypugh on topic Need help setting up a lathe(Sherline)
I think that there is something to be said for starting with a parallel port and a cheap integrated driver board.
www.ebay.co.uk/itm/CNC-3-Axis-TB6560-Ste...ma17-23/273503456084
For example.
You might well end up not using that for your machine, because you will probably blow it up before then
But you will learn a lot in the process and then have a better idea which way you want to go.
I started with one of those, blew it up, replaced a driver, blew it up again... (The TB6560 is fairly fragile, a loose motor wire will do for them)
Eventually I ended up with discrete black-box stepper drivers and a Mesa 7i43, but I wouldn't have known that was the way to go without the early experiments.
For example.
- kbec
28 Dec 2019 17:31 #153370
by kbec
They recommend me get the 7I96. So I'll go with that. I'll need the drivers too, I am not sure about what they mean by open and closed loop. I got the Sherline Nema 23 motors.
- Leon82
28 Dec 2019 19:09 #153374
by Leon82
Closed loop has an encoder so the drive will compensate for a lost step.
I think you said already got your steppers though
- kbec
29 Dec 2019 15:51 #153444
by kbec
Thanks, I am guessing they are not closed loop since they look pretty simple.
- kbec
08 Jan 2020 00:55 #154282
by kbec
How did you construct your controller box?
I have the 7I96 ,
a 36v 360 Watt power supply, and
4 STEPPERONLINE CNC Stepper Motor Driver 1.0-4.2A 20-50VDC 1/128 Micro-step Resolutions for Nema 17 and 23 Stepper Motor cards.
I was also wondering what type of wire I should use to cable everything
I have the 7I96 ,
09 Jan 2020 01:08 #154376
In what sense? I use pink, mainly
- kbec
09 Jan 2020 01:57 #154388
by kbec
like the awg size, solid or not, if there are like ribbon cables kind of thing.
09 Jan 2020 02:03 #154390
Use stranded with ferrules where it is in cable clamps.
Use AWG suitable for the current. Logic wires need not be any bigger than 26awg, and smaller wires take up less space.
For wires that move, look at dedicated drag-chain cables.
Moderators: piasdom
