Emco PC Turn Turret
5 years 1 month ago #221498 by Jpotts13
Replied by Jpotts13 on topic Emco PC Turn Turret
Hello.
I am trying to find out some details about this turret control.  I am having some problems with mine and thought that maybe someone on this thread could. help.
A few things are happening on mine...
D2 was burnt pretty badly and I dont have any markings on mine to replace.
Could anyone verify what D1 and D2 markings are on the diodes?
Lastly, the 100Watt resistors are getting really hot.  I dont feel like this is normal, although I expect them to get warm, they are discoloring the PCB.
Any thoughts, or help?
Jason
5 years 1 month ago #221511 by tommylight
Replied by tommylight on topic Emco PC Turn Turret
100W resistors normally do get very hot during use, is the value correct?
5 years 1 month ago - 5 years 1 month ago #221845 by Jpotts13
Sorry meant 100 OHM 4watt
Last edit: 5 years 1 month ago by Jpotts13.
5 years 3 weeks ago #222766 by The Feral Engineer
Hate that I'm so late to the game here, but I've got a perfectly working classicladder config for these machines i can send you if you still aren't having luck
theferalengineer@gmail.com
4 years 2 months ago - 4 years 2 months ago #249549 by Samuelx
Replied by Samuelx on topic Emco PC Turn Turret
I am trying also to make my turret move. Emco 50 pc turn.
I ask my friend that is good on electronics what to do. Because there is 5V and 24v involved. He say, that I only need 2 x opto (tlp 291) and to 2 x resistors (10k ohm)I think some other optos will work too, but this is what he had on home.So we use them.
So here is what you can do to change turret optosensor 5v signal to 24v signal.
  If you look at the picture where i hold board on hand. There is 3 leads that goes out from board:White lead goes to mesa board input 1Red wire goes to mesa board input 2black wire goes to mesa board input com
The other wire with 10K ohm resistors:
yellow wire goes to mesa board input 1
another yellow wire goes to mesa board input 2
both yellow wires has 10K ohm resistor.
red wire goes to 24v power +
I also draw opto pinout to picture
Pin 1 is connected to turret optosensor signal (there is 2 signal 1 for home and another signal for every tool)
Pin 2 is connected to turret optosensor (5v ground)
Pin 3 is connected to mesa board input com
Pin 4 is connected to mesa board input
Pin5 is for controlling the board. when +24v is connected to this pin, turret motor starts move forward. When there is 0V motor is moving backwards.Hope this helps someone who want to use the orginal turret control board.
Edit. Today I  tested this modification, its working great.
Last edit: 4 years 2 months ago by Samuelx.
2 years 11 months ago - 2 years 11 months ago #286171 by Murphy
Replied by Murphy on topic Emco PC Turn Turret
 @evengravy Hi could you share the classic ladder mod you needed to change for the 6 position tool changer please.
Last edit: 2 years 11 months ago by Murphy.
Time to create page: 0.509 seconds
