Turning a 6mm sphere produces a bullet shape.
- stoomraider
10 Dec 2021 18:16 #228791
by stoomraider
Turning a 6mm sphere produces a bullet shape. was created by stoomraider
I am experiencing a problem trying to machine a 6mm dia ball. I am using a parting tool to machine front and back curves. The front curve is fine, but after moving tool to compensate for the tool width, and then continuing with the corrected arc, the result is a failure, ending up as a bullet shape. I have used ECAM (free on weekends) to produce the gcode, tried both the radius and IK methods, but same result. The back curve just does not come out correctly.
Anybody got any idea's. Is it my cheap eastern breakout board, or does LinuxCNC have an as yet undiscovered flaw?
- Thank you received: 4648
10 Dec 2021 20:35 #228809
Replied by andypugh on topic Turning a 6mm sphere produces a bullet shape.
What sort of bullet?
Do you mean that the rear curve is not machined at all?
What does the g-code preview look like on the screen?
- Muzzer
- Thank you received: 42
10 Dec 2021 22:46 #228828
by Muzzer
Replied by Muzzer on topic Turning a 6mm sphere produces a bullet shape.
The Fusion turning CAM is pretty good now. There are a few features still under development (such as adaptive roughing) but it's all free and the preview is pretty powerful.
knowledge.autodesk.com/search-result/caa...8F0A5FA28B5-htm.html
- stoomraider
11 Dec 2021 04:26 #228845
by stoomraider
Replied by stoomraider on topic Turning a 6mm sphere produces a bullet shape.
The front is fine, the rear deformed, a parallel band then a sharp curve to the stem the ball is mounted on. However, I have detected some backlash in the X ballscrew, so I will add a backlash move, X 7, X6 at the quadrant point after tool compensation z move. The preview in LinuxCNC shows an elongated ball, circular front and back with a parallel portion, as expected.
(I have found that Mach3 and LinuxCNC don't always interpret the code the same way.)
- stoomraider
11 Dec 2021 18:52 #228884
by stoomraider
The problem was found to be the result of a failing ballscrew nut on the X axis.
Thank's for your interest. I shall replace the nut.
I'm pleased to know LinuxCNC and the BoB are not at fault. I enjoy working with LinuxCNC
04 Jan 2022 23:28 #230808
For reference, here is a 1.5" sphere made with LinuxCNC and Fusion CAM:
photos.app.goo.gl/y73FJ1QQxTdkyhHu6
So the combination definitely works (the slight flat at the equator is deliberate, presumably for grease distribution)
- stoomraider
05 Jan 2022 04:16 #230825
by stoomraider
Interesting job.
Backlash would seem to be my problem. I have implemented it now on LinuxCNC and Mach3. At the moment I have made enough satisfactory items. I am awaiting a carbide parting tool and holder as advertised in eBay and others.
Moderators: piasdom
Time to create page: 0.500 seconds
