Standard-modern 1700 series retrofit
3 years 3 weeks ago - 3 years 3 weeks ago #282435 by Trav328
Got the spindle encoder issue sorted so I have rpm display , also found out that the encoder scale needed to be negative as my a/b must be reversed , now have spindle synchronized motion working , time to put the guards back on and start some test cuts.
Ignore the backwards x move , I have been working on my lathe post and flipped my x around along the way.
Last edit: 3 years 3 weeks ago by Trav328.
The following user(s) said Thank You: RotarySMP, tommylight
3 years 1 week ago #283395 by Trav328
For the first time in 15+ years the standard modern 1700 is cutting metal , got the tool changer sorted out and did some test cuts in plastic before making up a jt1 Arbour.
Hige shout out to the people around here for all their knowledge.
Have to sort out my g2/g3 ijk in my cam post but we're on our way.
The following user(s) said Thank You: tommylight, besriworld
3 years 1 week ago #283396 by tommylight
The following user(s) said Thank You: Trav328
3 years 1 week ago #283397 by Trav328
The iron was in too good of shape under all the storage grime , i couldent let it go to be chopped up.
3 years 1 week ago #283399 by Trav328
Do you happen to have an example of g2/g3 in a lathe program ? I have tried every combo I can output in my ancient mastercam but I'm always getting the "radius to end of arc differs from radius to start" error
Might make my post modification easier if i can see an example.
3 years 1 week ago #283464 by Trav328
Got my mastercam post sorted out , was trying to cut rads in diameter mode.
Broke in the retrofit on some 2.5" 4140 for a auger shaft , im in love with this machine.
Time to create page: 0.319 seconds
