LinuxCNC Lathe Retrofit ... Where Do I begin?
- MusicCityMfg
05 Oct 2025 22:38 - 06 Oct 2025 08:05 #335893
by MusicCityMfg
LinuxCNC Lathe Retrofit ... Where Do I begin? was created by MusicCityMfg
I have a small CNC job shop in my garage. I currently have a Sharp SV-2412SX VMC with a Fanuc control. I need to start taking some turning jobs. I have an Emco Maximat Super 11 manual lathe that I was thinking about doing a LinuxCNC conversion on. But the more I think about it, I want a heftier, more capable CNC lathe with an ATC. But I am not ready to drop another $25k+ on used machine.
Someone local is selling a Mazak QT8 with a CAM T-2 control for $2500. It needs work and it looks like a good candidate for a LinuxCNC retrofit.
I'm a software engineer by profession. I don't know much about LinuxCNC yet, but I am learning. I'm currently going through some classicladder tutorials, and HAL tutorials as well to get my head around what it takes to do a retrofit and better understand the LinuxCNC ecosystem.
Do you guys have any recommendations on where I should begin to better understand what existing components on the Mazak QT8 I can use and what existing components will need to be replaced because they won't work with LinuxCNC. I have a lot to learn, but I am not intimidated by projects like this. I just need some advice regarding the best place to start and how a map out a project like this.
Thanks!
Chris
Thanks!
Chris
Last edit: 06 Oct 2025 08:05 by MusicCityMfg.
- jschulze
- Thank you received: 15
06 Oct 2025 09:10 #335919
by jschulze
Replied by jschulze on topic LinuxCNC Lathe Retrofit ... Where Do I begin?
Here's a guy that did a QT8 retrofit. Could try reaching out to him to see what was involved. I'd try to find out what issues the lathe has and plan from there. From a very quick look it looks like the servos have resolvers, so you'll have to plan for that with your choice of controlled cards or plan on replacing the servos and drives with something more modern with encoders.
The following user(s) said Thank You: MusicCityMfg
- Thank you received: 7505
06 Oct 2025 11:04 #335925
Replied by tommylight on topic LinuxCNC Lathe Retrofit ... Where Do I begin?
I did a Mazak MS15
forum.linuxcnc.org/show-your-stuff/32784...-15-retrofit?start=0
- MusicCityMfg
06 Oct 2025 11:21 #335926
by MusicCityMfg
Replied by MusicCityMfg on topic LinuxCNC Lathe Retrofit ... Where Do I begin?
Thanks! I saw your post and started reading it. There's a lot there.
Were you able to replace the resolvers with encoders? Are they part of the motors?
I ask because I found a video of some guy who did a Nakamura LinuxCNC retrofit and he opened up the Fanuc spindle motor and replaced the Fanuc encoder with one he bought off of Alibaba. He had to machine a custom mount for the encoder.
I don't know if the resolver process is similar or if I have to buy all new servos.
06 Oct 2025 19:50 #335967
For resolvers, you should really try to find as much info as possible, preferably full spec sheet, and preferably push as much as humanly possible to use them, Mesa has resolver cards.
Yes.Were you able to replace the resolvers with encoders?
No they were/are mounted on the screw shaft, not on the motors.Are they part of the motors?
- MusicCityMfg
07 Oct 2025 08:06 - 07 Oct 2025 08:20 #336004
by MusicCityMfg
@tommylight I'm curious why you are recommending that I push to use the resolvers instead of switching to encoders? Shouldn't I want to use the latest and greatest technology when possible?
Last edit: 07 Oct 2025 08:20 by MusicCityMfg.
07 Oct 2025 10:06 #336013
Resolver can have much, much higher resolution, depending on the card used for them and the ADC used.
Also, they never fail, at least i have never seen any failed ones.
Moderators: piasdom
Time to create page: 0.225 seconds
