Altaros tool changer driver
  • andypugh
  • andypugh's Avatar Topic Author
  • Moderator
  • Moderator
23 Dec 2025 12:58 - 23 Dec 2025 12:59 #340417 by andypugh
Altaros tool changer driver was created by andypugh
Altaros make a relatively inexpensive 8-station tool changer for CNC lathes. www.altaros.cz/accessories/157-automatic...ead-for-8-tools.html  I don't have one to test with, but I have written a driver for it (as a user space Python HAL component).
I needed to add .py to the end of the filename to upload it. This should be removed to install the file
loadusr -W ./altaros_ath
# pre-selecting a tool isn't applicable on a lathe
net tool-prep-loop iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
# tool change loop is handled in the altaros_ath component
net tool-change iocontrol.0.tool-change => altaros_ath.tool-change
net tool-changed altaros_ath.tool-changed => iocontrol.0.tool-changed
net pocket iocontrol.0.tool-prep-pocket => altaros_ath.pocket-num
net oddeven sim_toolchanger.strobe => altaros_ath.strobe
net tool-step altaros_ath.actuate => sim_toolchanger.actuate
To install the component, place the "altaros_ath" file in the same directory as the INI file of the LinuxCNC config being run, and make it executable. (chmod +x altaros_ath)
Last edit: 23 Dec 2025 12:59 by andypugh.
The following user(s) said Thank You: tommylight, Aciera
Moderators: piasdom
Time to create page: 0.082 seconds
