Mesa/HAL/.ini examples for set up - care to share?
- 1:1
26 May 2011 05:49 #10081
by 1:1
Mesa/HAL/.ini examples for set up - care to share? was created by 1:1
Hello all,
I have a new Mesa 5i22 (1.5) and a 7i33 card here - I want to run a 3 axis + servo spindle mill in EMC2 via hostmot2...
I know a heap of you are running similar systems - can anyone post here or email the HAL and .ini files and whatever else were required to 'wire up' the mesa cards/pins to get your system running ?
I know your system might be different but it'd be a great help for learning being able to reverse engineer your files - any other info would be great also...
So far I have just got to:
loadrt hostmot2
and then the firmware/config lines (I'm not at my linux machine at the mo' to copy it) - although it was just to test it works, still have to actually decide what I need to configure:ohmy:
cheers,
Nick
loadrt hostmot2
cheers,
Nick
- Rick G
- Thank you received: 155
26 May 2011 09:58 #10084
by Rick G
Replied by Rick G on topic Re:Mesa/HAL/.ini examples for set up - care to share?
- BigJohnT
- Thank you received: 1176
26 May 2011 11:42 #10088
by BigJohnT
Replied by BigJohnT on topic Re:Mesa/HAL/.ini examples for set up - care to share?
Or use one of the sample configs that match your hardware... then adapt to your special needs.
- 1:1
26 May 2011 12:12 #10090
by 1:1
Replied by 1:1 on topic Re:Mesa/HAL/.ini examples for set up - care to share?
ahhhhhh...
pncconf
thats what I've been looking for - great to get started, the tricky stuff can come later!
pncconf
