5i20 7i48
- fgauder
04 Jan 2012 16:30 #16301
by fgauder
5i20 7i48 was created by fgauder
I have no idea where to ask this question, so I thought I'd start here. I'm starting up a Hurco MD3 mill conversion. The mill has Servomate drives and I'm controlling them with Mesa 5i20 and 7i48 cards.
I have a problem with the X axis scale, so I've only been able to move the Y and Z axes. Both of these move smoothly in one direction, but in the opposite direction the whole machine shakes, the ECC (excess continuous current) LED comes on, and Hal Scope goes from a smooth line on axis.n.f-error to a rapidly oscillating line with 20x's the magnitude of the other direction.
If I reverse the armature and tach polarity, the shaking goes to the opposite direction. As usual, I'm clueless and in need of help. Thanks
- Thank you received: 4987
04 Jan 2012 16:41 #16303
Replied by andypugh on topic Re:5i20 7i48
fgauder wrote:
Is your PWM type set to 2? You need up-down mode (PWM on both pins) otherwise the "negative PWM" pin sees "direction" values instead.
This is a HAL file setting.
- fgauder
04 Jan 2012 17:09 #16309
by fgauder
Replied by fgauder on topic Re:5i20 7i48
Thank you Andy. That was the problem.
Time to create page: 0.056 seconds
