Mesa 7i29 wiring an capacitors with 2KW servos
- nursum
14 Feb 2012 12:24 #17657
by nursum
Mesa 7i29 wiring an capacitors with 2KW servos was created by nursum
I'am running a big 4-achses milling centre with EMC2 and its old Simens drives. Now I'am planning to use the 7i29 drivers. Who have experiance with that cards and Motors with 2KW power each?
In Germany we have 230V AC and not 110V so I'have to transform the power...
Mesa writes in its manual that it is important to use the right size of capacitors... are these capacitors located at the source or the output of the 7i29?
Is a separate break unit necessary? How do you handle the complete power system to get less nois and no overvoltage?
Ingo
Ingo
- Thank you received: 5252
14 Feb 2012 14:48 #17665
Replied by PCW on topic Re:Mesa 7i29 wiring an capacitors with 2KW servos
Do you have the motor ratings available? The 7I29 may be too small for this application
(it may also be too low voltage if your servos ran off line voltage before)
Depending on how close you are to the maximum 7I29 voltage and the power
supplies output capacitance you may need an external brake circuit
- nursum
14 Feb 2012 15:01 #17666
by nursum
Replied by nursum on topic Re:Mesa 7i29 wiring an capacitors with 2KW servos
the motor have maximum 163V with 13.5A and a power of 1,9KW. Actually I'am not shure what inuctivity the motor has..
- jCandlish
- Thank you received: 4
25 Apr 2012 16:35 #19532
by jCandlish
Replied by jCandlish on topic Re:Mesa 7i29 wiring an capacitors with 2KW servos
Bump.
An application note for the 7i29 discussing suggested circuits for nominal 150v/10A servomotors would be quite handy.
- nursum
25 Apr 2012 19:23 #19533
by nursum
Where is it?
