Mesa 5i20 -> 7i42a -> 7i47s -> geko 203v X3
16 Feb 2012 14:48 #17716 by PCW
from the previous table, STEP0 and DIR0 are the first axis step and dir signals
16 Feb 2012 16:52 #17719 by vladilinsky
Replied by vladilinsky on topic Re:Mesa 5i20 -> 7i42a -> 7i47s -> geko 203v X3
Amazing, it spins!!!. What I had a hard time wrapping my head around, was I needed to leave the encoder option as "unused encoder" because it auto-gens the direction signal from that terminal.
Thanks so much
17 Feb 2012 03:20 #17748 by cmorley
Not sure what you mean. The encoder should have nothing to do with the step gen's pins.
You should be able to use the encoder for anything you like while still using the step gen.
But I'm glad you got it going!
17 Feb 2012 22:07 #17771 by vladilinsky
it very possible i do not have any idea.what is going on :) but what i am talking about is i have one control wire going to step on the gecko from tx4 and one from tx5 to dir on the gecko. In my setup i have 0 set to step gen and the corrisponding 0 set as unused x axis encoder. Is it possible that step gen controls the dir aswell?
18 Feb 2012 04:36 #17780 by cmorley
If you look at the pintype column it tells you the signal type.
for instance a stepgen had a pintype of step (step gen a) and a pintype of direction (dir gen a).
The number is the component number.
for instance there are 4 step gens numbered 0-3
There are 4 encoders numbered 0-3
Moderators: PCWjmelson
Time to create page: 0.065 seconds
