7I42TA Question
11 Mar 2012 04:27 #18521 by Dave3891
7I42TA Question was created by Dave3891
I am upgrading my plasma machine from a 3 axis(4 stepper, 1 axis slaved) to a 6 axis (7 stepper, 1 axis slaved) machine and I wanted to know if I could get all 7 motors on one 7I42 card?
If not which card can do the most step/direction ports?
Dave
11 Mar 2012 09:36 #18523 by cncbasher
Replied by cncbasher on topic Re:7I42TA Question
the 7i42 is an addon card which supports 24 connections , you'd need 2 connections per stepper pulse & direction , so that takes care of 14 pins , if your looking at using an enable for your stepper drives that can be handled by one pin and just take all the to that point
you would then need limit switches and other ancilary uses etc .
you do not mention which mesa interface fpga you already have , i.e 5i20 , 7i43 etc , so depenadant on your interface you have 2 or 3 ports available so either 48 or 72 available pins
the mesa 7i42TA connection interface addon can support up to 12 stepper interfaces i.e one 7i42 card in full i.e 24 pins
11 Mar 2012 12:39 #18527 by BigJohnT
Replied by BigJohnT on topic Re:7I42TA Question
You might want to look at the 5i25 7i76 combo of cards which is what I just put on my plasma. Of course you would need two 7i76 cards for 7 separate drives.
What are you doing with all the extra axes on the plasma?
11 Mar 2012 13:48 #18529 by Rick G
Replied by Rick G on topic Re:7I42TA Question
Dave,
The one axis you have slaved, if you do not intend to home / jog it separately from the master axis you can drive both the master and the slave from the same pins.
Rick G
11 Mar 2012 16:13 #18531 by Dave3891
Replied by Dave3891 on topic Re:7I42TA Question
I am using 2 extra axis for a bevel head to bevel around the complete profile. And one more axis to add rollers off to the side of the table to allow pipe cutting.
I guess I will learn about kinematics when I setup the 5 axis head :)
I have ordered the 5I20 card with a 7I42TA along with another io card from mesa (cant remember the number but its the one with the transistor outputs good for 1 amp)
I am connecting this to two gecko G540's
Dave
Moderators: PCWjmelson
Time to create page: 0.065 seconds
