Does Mesa 5i20 require +5V/GND on TB1
02 Apr 2012 16:37 #18928 by Will Gilmore
Does Mesa 5i20 require +5V/GND on TB1 was created by Will Gilmore
I looked through the 5i20 manual and it doesn't show that connector or mention it in the text. Does TB1 need +5V/GND? If so, should it come from computer power supply or the external 5V power supply I have set up for the 7i37TA and the 7i48? Or should they all run from the computer power supply?
Thanks.
02 Apr 2012 16:42 - 03 Apr 2012 02:00 #18929 by PCW
TB1 on the 5I20 is a 5V output
Note that the 7I37should run fine with cable 5V as it draws so little 5V power
The 7I48 and attached encoders may draw substantial 5V power so it often needs external 5Vpower
The 5I20s TB1 can be used as a source of this power for the 7I48
Last edit: 03 Apr 2012 02:00 by PCW. Reason: sp
02 Apr 2012 17:33 #18932 by Will Gilmore
Replied by Will Gilmore on topic Re:Does Mesa 5i20 require +5V/GND on TB1
Thanks. I'm sure there will be many more questions to follow.
01 Jul 2012 17:52 #21473 by doug6949
Replied by doug6949 on topic Re:Does Mesa 5i20 require +5V/GND on TB1
Does this apply to the 7i33 as well? And if I use external power on TB1 does this isolate the computer from I/O on the 7i33?
I am using a 24VDC supply for all digital I/O on the 7i37
Doug
01 Jul 2012 21:15 #21475 by PCW
Its really only needed on the 7I33 if your encoders draw a fair amount of power (say more than 150 mA each) or if you have along flat cable. The 7I33 IO is buffered but not isolated from the PC
Moderators: PCWjmelson
Time to create page: 0.066 seconds
