Re:Mesa 7i77 differencial encoder connection.
14 years 5 months ago #20025 by ishman
Thanks again PCW ! And thanks for heads up as well !
I have uploaded the file at filebin.ca and updated previous post as well.
filebin.ca/1UQcJ0K53d6/schematic.pdf
14 years 5 months ago #20033 by PCW
The ZOC pins appears to be a open collector version of Z (index) signal
not sure what its good for
6 years 5 months ago #166924 by Becksvill
hey peter
just a quick question on this same issue this thread is the closest thing to what I want to know.
I have the same setup as above. I am using my servo drive to output the encoder outputs to the mesa 7i76 spindle encoder card.
as far as I understand the drive powers the encoders and the mesa card doesn't need 5v connected.
so here are the questions:
1 do I need to use a signal ground at all if using differential encoder signals?
2 I am currently powering the 7i76 5v logic power from 5i25 is that going to be a problem if connecting encoders?
I will attach a screen shot of the encoder stuff in the manual.
6 years 5 months ago #166925 by Becksvill
here is the manual I am asking about. I have a build thread that may be a better place to ask and if so just let me know and I will ask there.
6 years 5 months ago #167138 by andypugh
Becksvill wrote: 1 do I need to use a signal ground at all if using differential encoder signals?
The input common-mode range for the encoder is -7 to +12 volts relative to signal ground. You night need a common gnd to ensure that this is not exceeded.
Measuring the gnd offsets with a multimeter might be worth doing initially.
6 years 5 months ago #167188 by Becksvill
awesome! thanks andy
that is a very good piece of info to know
I just checked between the 24v io ground on the mesa card and the logic power ground and they are within 1.5 v
So I am good to go.
connecting up now.
Andrew
Moderators: PCW, jmelson
Time to create page: 0.126 seconds
