2 Mesa Cards
- punisher454
05 Jul 2012 10:05 #21604
by punisher454
Replied by punisher454 on topic Re:2 Mesa Cards
Please be sure to keep us updated on your results. I am planning to run the same VFD + Mesa.
Marvin
Marvin
- brianm
13 Jul 2012 15:26 #21893
by brianm
Replied by brianm on topic Re:2 Mesa Cards
I ended up buying a RS-485 PCI card. I also changed the cable to a CAT 6 cable. So far everything is working. I have not run the machine that much though. Some how in the process of working I ended up breaking my mesa 5i20 card. I think it had been going bad for awhile and finally died. There were times where the hostmot driver would not load and I would have to take the card out of the computer and reinstall it to get it to work. Luckily my plasma machine uses the same card so I can use that one until I get a new one. After I have to run an order of 300 parts so I can see if the problem is solved.
- Online
- Thank you received: 5252
13 Jul 2012 15:52 #21897
Replied by PCW on topic Re:2 Mesa Cards
If reseating the card fixes things temporarily I would suspect the card/card slot of being contaminated. Cleaning the slot/card edge connector with 99% Isopropyl alcohol should help in this case.
Another possibility is a mechancal intermittant on the 5I20 card (possibly a bad solder joint) If cleaning the card/slot does not fix the problem the card should be returned for warranty repair.
- brianm
13 Jul 2012 16:12 #21898
by brianm
I tried cleaning everything. I thought it might be the slot. but my other card works in both machines and this card does not work in either machine. I will send it in to see if it can be repaired.
- brianm
13 Jul 2012 18:21 #21909
by brianm
Looks like it is the RS-485 card some how breaking the mesa card. Now the other card does not work in either machine. I was running a program in the machine and suddenly it gave me a joint following error and the entire computer crashed. Then when I rebooted, I can no longer load the driver. One thing that I have noticed is that after this happens the board gets extremely hot. there is a component on the board labeled u4 that is very hot.
I will try and get these boards fixed and am going to change to controlling the VFD with a pwm signal.
- Online
13 Jul 2012 18:44 - 13 Jul 2012 18:51 #21914
U4 on a 5I20 getting hot means the local 3.3V power supply on the 5I20 is shorted out. This can be due to shorting a large number of FPGA pins to ground (backwards or bad flat cable is one way to do this) or a crowbarred FPGA due to exceeding its I/O pin voltage limits (This may be permanent = fried FPGA)
Any I/O pin pulled to more than 5.5V or below -.5V can cause the FPGA to crowbar which will short out the local 3.3V from U4, possible crash your computer and possibly cause permanent FPGA chip damage
Since this got worse when you installed the RS-485 card it may be that you have a ground loop in your system that is shunting current through the PC/FPGA card
Spindle drives are notorious as noise generators so this may be related
Last edit: 13 Jul 2012 18:51 by PCW. Reason: sp
- brianm
13 Jul 2012 19:14 #21916
by brianm
I do have a rats nest that I will have to sort out. If I got the 7i42Ta would that potentially avoid this problem in the future?
- Online
13 Jul 2012 19:24 #21917
Yeah if you are using bare FPGA pins you have to be really careful with what connects to them (even for a microsecond)
- Thank you received: 4987
14 Jul 2012 21:59 #21949
Replied by andypugh on topic Re:2 Mesa Cards
I think I saw your lathe on YouTube. It's an impressive machine.
- brianm
14 Jul 2012 23:23 #21955
by brianm
The you tube video I just posted is:
Thanks for the comment. It works quite well mechanically.
I finally just finished the turret and live tooling motor setup.
Unfortunately, electronics is not my strong point and with all the solenoids VFDs and everything else, I have managed to create quite a rats nest of cables. (That in the end I think destroyed my mesa card). While I wait for the new card I am going to clean up the wiring. I also ordered the mesa cards to opto-isolate the PCI card. (Should have done that in the beginning but ....) I am also thinking of opto-isolating the RS-485 connector to the computer. I have only found one "black Box" that does that and it costs $160. So, I am not sure that it is required.
One big problem I believe I have is I am not using shielded cable from the VFD to the motor. I cannot seem to find shielded cable from any of the local electrical supply stores - so will have to order it.
I am in the process of making a tool that will drill radial holes that mounts to the turret. (Unfortunately or fortunately I guess other work for customers is taking priority.)
Time to create page: 0.097 seconds
