Mesa 7i39+5i20
- Thank you received: 5018
sudo make setuid
stage of the compile. You will need to type the root password after that command.
- nikos.chalikias
I forgot it was sudo.... and asking the password!!!!!!
I did not enter the password.
I was running too fast...
Sorry for the trouble.
I can start EMC2.5 now
I can also close it and run it again, so the restart problem is now fixed.
Nikos
The next few days should see the release of a new "bldc" component into the development branch that combines the functions of bldc_sine and bldc_hall into one much more capable component (it will, for example, start a motor with hall sensors and an encoder in hall/trapezoidal commutation then switch to sinusoidal commutation once it has an angle fix from a Hall transition or (optionally) from the encoder index.
It has been extensively tested with the 7i39.
- nikos.chalikias
I am wondering how to combine BLDC, step-motor and DC-motor in the same machine.
The Machine under construction is a Pick-Place.
- X,Y are NEMA23 BLDC to be fast and presise.
- The head (Z is included in the head) should be DC motor (weight 20 gram) and linear encoder, due to low mass of the motor, low cost and good speed
- The rotation of the component (axis A) is included in the Z plate. It should turn very presisely and be very light. Best approach (...found yet) is a small Step-motor (60grams -2oz with 200 steps/rot) and microstep driver.
I could use CPU-CONTROLED DC-SERVO-BOARD and STEP-DRIVER-BOARD and EMC2 to see only a digital line for each board, but this is not ...so smart!
5i20 with BLDC,DC,STEP boards is better
Any Idea?
Nikos
I think a small brushless motor might work better, it should certainly last longer.
A stepper motor is probably a good solution, but there is no reason that a brushless motor with an encoder couldn't work equally well, and might be faster.
- nikos.chalikias
- Encoder works
- BLDC Initialization after ESTOP released works
- After many times ESTOP press-release-cycles, DRO always returns to the same point but not exactly at zero
- If EMC2.5 is closed and restarted then the above position is slightly different
- If ESTOP pressed and released again then JOG is possible for the same distance as above
- Starting EMC2.5 sometimes starts at X=0, Y=0, sometimes at X=1056 or X=-1056. With current configuration starts at 0,0
Encoder is 500 cpr
one rotation moves the carriage 32.512mm
Motor is BLDC NEMA23 at 24V
bldc_sine.hal, I am using is attached (Encoder and PID configured there!)
You have bldc_sine.0.scale as 2000. That is very unlikely to be right with a 500cpr encoder.Now that it is possible to restart EMC2.5 I am trying to move one BLDC motor
Encoder is 500 cpr
Do you know how many poles your motor has? If you apply a very small current to the motor between any two phases you should be able to feel them, normally 2, 3 or 4 "pulses" will be felt turning the motor by hand for 4, 6 or 8 motor poles.
By how much does rawcounts increase with one full revolution of the motor?
The bldc_sine.0.scale value needs to be one full revolutions-worth of rawcounts divided by the number of motor poles. (the scale is how many counts there are per _electrical_ revolution)
Bear in mind that bldc_sine has not been released, and in fact is never going to be released, it has been replaced by a much more capable .comp called simply "bldc" which handles all motor types. This component uses a different way to define the scale, as I realised that 6 pole motors were impossible to give an accurate enough scale to.
- nikos.chalikias
- nikos.chalikias
Encoder is 500cpr so the rawcount should be 2000 (?)
so
setp bldc-sine.0.scale =500
But still not working.
Also tested 4 8 10 16 32 32.250 32.512 33 62.5 64 83.333 100 128 125 250 333.333 500 1000 2000
with similar result.
Values around 32, additionally create a crazy movement after a try to JOG
All other values allow only some mm to JOG, then [joint 0 following error]
IF YOU HAVE STOPPED DEVELOPING bldc_sine
Is it good idea that I continue trying with your new component "bldc" ????
- nikos.chalikias
I read carefully www.linuxcnc.org/docview/devel/html//man/man9/bldc_sine.9.html
I tested negative value 1000
as
setp bldc-sine.0.scale -1000
And now it works.
I can move with 48000 mm / min (48m/min) or 800mm/sec !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
very smooth and quiet
