Mesa 7i39 + 5i20 + Pittman ELCOM ST BLDC
26 Jul 2012 17:13 #22494 by karl1
Question for the experts:
I setup the following combination of components:
Pittman ELCOM ST BLDC Motor - uses 34 pattern for hall effect sensor commutation. 4 poles.
24VDC power supply
USDigital Encoder model E5S-1024-315-IG - no index, no compliments for A or B signal.
two Mesa 7i39-LV - about 2 years old, but never got to work before recent LinuxCNC update. These are on connectors P2 and P3 of the 5i20.
Mesa 5i20 card - works well; I also have a 7i33 that I've used to test other motors and amplifier combination. The 7i33 is not wire into this setup.
using LinuxCNC 2.5
Used PNCconf, and with some tweeking, I have movement from the above setup.
Problem is there is no feedback from the encoder in LinuxCNC, and I'm sure I'm missing the needed HAL components for this. When running the Axis demo g-code, seems to run away, but does reverse directions. When I turn motor shaft, no feedback; display never changes x axis values.
I only have one axis, the X-Axis, wired for now. Motor is not coupled with anything.
Could someone who has worked with both Hall Sensors and Encoder Feedback post a HAL and INI file that they have working? I'm glad I have movement, and really anxious to tie the x-axis into LinuxCNC, before I wire up the remaining motors.
I've attached my HAL and INI files for this setup.
Thanks!
Karl
File Name: bldc_hall.gz
File Size:2 KB
26 Jul 2012 17:52 #22495 by BigJohnT
Replied by BigJohnT on topic Re:Mesa 7i39 + 5i20 + Pittman ELCOM ST BLDC
Do you have the Mesa card jumpered for single ended encoder input? Usually there is a jumper for this on the card, I've used the 7i33 and 7i77 on servos but not the other one.
26 Jul 2012 18:20 #22496 by karl1
Board has no jumper for encoder selection; it has just A, B and Index connections, along with power and ground.
27 Jul 2012 02:59 #22503 by PCW
First I would verify encoder operation by itself by looking at encoder 0 postion with a halmeter when you rotate the motor shaft. If this does not work, verify the 7I39/encoder connections, and the 7I39/5i20 connections (check dmesg for which 5I20 pins and connectors the encoders are on)
27 Jul 2012 12:12 #22516 by karl1
Thank you Peter for the insight.
I am embarrassed to say that the wiring was correct, but the lack of any signal was purely a rookie mistake.
I literally have a hundred of these motors in my scrap bin - all next to new. I happen to grab one for this testing that I had removed the encoder's optical transmissive module; this happened about a year ago when I was troubleshooting an encoder problem. The electrical connector snapped and latched into the housing. I never bothered to check "under the cover", and when I finally removed it to replace what I thought was a blown module, I was shocked to see it missing. Funny that I should meet it half way with a signal. :laugh:
I just need to get the rotation of the motor feedback to match the proper direction in LinuxCNC - throws a joint 0 error when commanding a positive motion and feeds back a negative. Anyone have a quick solution?
27 Jul 2012 15:08 #22529 by andypugh
Replied by andypugh on topic Re:Mesa 7i39 + 5i20 + Pittman ELCOM ST BLDC
Reverse almost any of the scales. Or pset the dir pin of bldc, or even find the other working Hall pattern or swap any two motor power leads or exchange A and B on the encoder or....
27 Jul 2012 20:58 #22540 by karl1
I works now! I ended up using the setp bldc.0.rev true and also assigned a negative number to the scale.
Studied the following link:
www.linuxcnc.org/docview/2.5/html/man/man9/bldc.9.html
Thanks all! I will post my final set up with pictures. Stay tuned.
27 Jul 2012 21:14 #22542 by andypugh
karl1 wrote:
Ihttp://www.linuxcnc.org/docview/2.5/html/man/man9/bldc.9.html
I do intend writing something rather more informative at some point.
Moderators: PCWjmelson
Time to create page: 0.416 seconds
