Moving Gantry router with 6i25
- Thank you received: 4967
Mesa tech support suggested reloading the flash if 2.5.1 didn't correct the problem. Do you think that's what I should try next?
Just to save confusion, PCW is Mesa tech support.
- PortlandGTS
Oh - I didn't realize that. I also e-mailed Mesa directly, and got a response from someone with initials PCW. Must be the same person.
Tom
- PortlandGTS
tom@CNC-Router:~/Desktop/5i25/configs/hostmot2$ ../../utils/linux/mesaflash g540x2.bit info
Checking file g540x2.bit...OK
File type: BIT file
Design name: TopPCITargetHostMot2.ncd;UserID=0xFFFFFFFF
Part name: 6slx9tqg144
Design date: 2012/05/10
Design time: 13:51:20
Config Length: 340604
tom@CNC-Router:~/Desktop/5i25/configs/hostmot2$ ../../utils/linux/mesaflash g540x2.bit verify
mesa 5i25 not found
Looks like Mesaflash can't find the board. Is it a coincidence that the UserID returned by Mesaflash is the same as the invalid cookie returned to HAL?
Regards,
Tom
Not really, 0xFFFFFFFF is "all bits high" the maximum 32-bit number which you get when there is no connection.
Has the card fallen out, changed ports ?
- Thank you received: 5217
Can you run a lspci -s N:n.0 -x and post the results?
where N:n.0 is the PCI bus and slot number (of the 6I25 (well it will show up as 5I25)
as listed by lspci with no parameters
This may be a BIOS related issue (not enabling access to cards on the other side of a bridge)
Theres a workaround for a similar BIOS issues in the hostmot2 5I20 code
- PortlandGTS
tom@CNC-Router:~$ lspci -s 03:00.0 -x
03:00.0 DPIO module: Device 2718:5125 (rev ff)
00: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
10: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
20: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
Did I get the right device?
Thanks,
Tom
in the config space
If this is not a hardware failure on the 6I25 card (and these symptoms would be hard to have with a hardware failure, that is reading some but not all of the config space) then its probably a BIOs error (not initilaizing devices on the other side of a bridge?)
It could also be a suble thing wrong with the PCI core that get triggered by somthing your motherboard does
this would be the first time I've seen this however.
What motherboard is this?
also can you do a lspci | grep -i XIO2001
and dump the config space of the XIO2001 (PCIE-PCI bridge chip on the 6I25)
if this was not setup properly by the BIOS this could cause these symptoms
- PortlandGTS
My motherboard is an Asus A8N-VM-CSM. I bought it about 2005, so maybe it doesn't implement PCI-E correctly?
Tom
One possibility is trying to update the BIOS on your MB if this cannot be worked around some other way
Also maybe just swapping the 6I25 with a 5I25 would be the easiest solution on the MB (since it has PCI slots)
- PortlandGTS
Maybe the best solution is to swap for a 5i25. I got the 6i25 because it would be more "future proof", but that's not worth all this complication.
I'm going to be out of town until Friday. I'll get back to you then about possibly swappng.
Thanks,
Tom
