Odd non-CNC setup
- Roguish
- Thank you received: 31
31 Oct 2012 10:32 #26114
by Roguish
Odd non-CNC setup was created by Roguish
Ok, so I need to control a non-CNC machine for test purposes. I will have at least 5 axes. Possibly more depending on how the first 4 work out.
2 axes will be 2 phase steppers with mechanical actuator combined with linear potentiometers for 'absolute' position control. 2 axes will use Animatics 'SmartMotors' with linear potentiometers for 'absolute' position control. 1 axis will use a 2 phase stepper with mechanical actuator and an incremental linear encoder for position control.
I am used to Mesanet hardware and really like it.
Problem is (are) the linear pots. How do I read them? suggestions for an A/D converter?
Also, the steppers.... what drive? The actual drive will be an MForce MicroDrive.
PCW can you layout a Mesanet configuration forEMC2 Linuxcnc control?
The final system will be controlled with EPICS Check it out.
- cncbasher
- Thank you received: 288
31 Oct 2012 16:59 #26118
by cncbasher
Replied by cncbasher on topic Odd non-CNC setup
if you mean rotary shaft quadtature encoders then you'll be fine .. but linear pots ( I presume LVDT) then you'd probably handle them as a resolver which again is an add on card for mesa io
can you link to the specific pots you are wishing to use , would be a good idea .
- Thank you received: 4966
31 Oct 2012 20:05 #26127
Not the cheapest possible solution, but the 5i25 / 7i76 to handle the steppers and a 7i87 plugged in to the RS422 port on the 7i76 to handle the analogue voltages ought to work.
(The mention of "buffered A/D reference for ratiometric applications" Sounds especially relevant to your application)
However is 12 bits of resolution going to be enough?
Replied by andypugh on topic Odd non-CNC setup
Problem is (are) the linear pots. How do I read them? suggestions for an A/D converter? .
- Thank you received: 5208
01 Nov 2012 01:17 #26155
Replied by PCW on topic Odd non-CNC setup
a 5I25, 7I85S plus a 7I87 might do as well
- Roguish
01 Nov 2012 08:09 #26167
by Roguish
Replied by Roguish on topic Odd non-CNC setup
Thanks for the help.
So, the linear pot are Novotechnik, T series. Pretty high quality.
The linear incremental encoder is a Renishaw TONIC with an RELM tape, sub-micron. Yes, it's a real requirement.
The actuators are Harmonic Drive LA-32-30 with Oriental Motor steppers. The HD has an 80:1 gear with a .5mm lead.
The other motors are Animatics SmartMotor SM23205D's.
I can use most any stepper drive as long it micro steps really small, like >20micro/step.
The final stepper drives will be Schneider MForce MicroDrives, microstepping.
2 actuators are coordinated motion, X & Y. The others are independent.
It does not have to run totally real time.
I would really like to stay completely MesaNet. Can this be done????
The thing is to put into a beam line at SLAC, run by EPICS, but I need to exercise it during test.
It's not a hobby deal, so cost is adequately covered.
I'm all ears, and need help.
01 Nov 2012 18:08 #26179
The Mesa 7i32 might be worth a look (but it is _not_ LinuxCNC compatible). It can be controlled by a Mesa FPGA card running (I think) SOFTDMC. That might make for an easier job to integrate with EPICS.
You are about 25 miles from Mesa, why not give them a ring?
I expect so, but are there Mesa drivers in EPICS?I would really like to stay completely MesaNet. Can this be done????.
- Roguish
03 Nov 2012 04:32 #26216
by Roguish
Sorry, Guess I wasn't very clear. My LinuxCNC setup will just be a simple test system to exercise the motion components. The final complete assembly will be installed at SLAC and controlled via EPICS.
on the side, check out EPICS and RTEMS !!!!
www.aps.anl.gov/epics/index.php
www.rtems.org/
www.rtems.org/
Time to create page: 0.136 seconds
