5i20,7i77 and 7i73 gpio setup
- JR1050
- Thank you received: 33
11 Nov 2012 09:01 #26443
by JR1050
5i20,7i77 and 7i73 gpio setup was created by JR1050
I recently ordered a 5i20 and 7i77 and I would like to set up my hal file. Im gonna be setting this up on a Cincinnatti lathe which is very similar to a Hardinge lathe which I have running successfully.So, the idea is to use the hal file and change the signal names and pin assignments.How are the i/o pins numbered on the 7i70 and are they called gpio or do they have another designation?
I also have a 7i37 and would like to define all my signals,any body know how these bits are designated.Thanks ahead of time.
- Thank you received: 4988
11 Nov 2012 09:18 #26445
(actually, it could work with a rather special cable and firmware)
Replied by andypugh on topic 5i20,7i77 and 7i73 gpio setup
That isn't a workable combination. Are you sure that is what you ordered?I recently ordered a 5i20 and 7i77
That depends on the startup mode. halcmd show pin and dmesg are your friends.How are the i/o pins numbered on the 7i70
The following user(s) said Thank You: JR1050
- JR1050
11 Nov 2012 09:49 #26447
by JR1050
Replied by JR1050 on topic 5i20,7i77 and 7i73 gpio setup
My mistake,5i25, not 5i20...Im so used to using the 5i20. Im trying to get ahead of the curve and get things set up before it arrives.
- Thank you received: 5254
11 Nov 2012 10:25 - 11 Nov 2012 10:33 #26448
Replied by PCW on topic 5i20,7i77 and 7i73 gpio setup
Here are the 7I77+7I73 pins and parameters:
freeby.mesanet.com/7i77+7i73.pins
freeby.mesanet.com/7i77+7i73.parms
Last edit: 11 Nov 2012 10:33 by PCW.
Time to create page: 0.069 seconds
