5i23 does not see stand alone encoders
- mariusl
07 Dec 2012 04:01 - 07 Dec 2012 04:09 #27339
by mariusl
Regards
Marius
www.bluearccnc.com
5i23 does not see stand alone encoders was created by mariusl
I am using a 5i23 set up for eight servo channels. Five of them have a pwm and and encoder driving a vfd and motor, but two have just got encoders.
Now the five channels work fine but I cannot seem to get the two encoders to give any data. When I look at the rawcount with Halmeter, They are both sitting at 65535.
Is there a special setup for channels that just read an encoder on the servo channel?
Regards
Marius
www.bluearccnc.com
Last edit: 07 Dec 2012 04:09 by mariusl.
- Thank you received: 5254
07 Dec 2012 04:08 - 07 Dec 2012 04:13 #27340
Replied by PCW on topic 5i23 does not see encoders
Which fpga configuration file and daughtercards are you using?
Also forgot to add:
When debugging encoder inputs, a good thing to try is reading the A/B inputs as GPIO bits and making sure both toggle
Also forgot to add:
Last edit: 07 Dec 2012 04:13 by PCW.
- mariusl
07 Dec 2012 04:14 #27341
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic 5i23 does not see stand alone encoders
This is what I load:
loadrt hostmot2
loadrt hm2_pci config="firmware=hm2/5i23/SVST8_4.BIT num_encoders=8 num_pwmgens=5 num_3pwmgens=0 num_stepgens=0 ,firmware=hm2/5i23/SVST4_8.BIT num_encoders=0 num_pwmgens=0 num_3pwmgens=0 num_stepgens=0 "
The daughter boards are 7i33 and 7i37.
The encoders are on the first 5i23
loadrt hostmot2
Regards
Marius
www.bluearccnc.com
07 Dec 2012 04:37 #27342
Replied by PCW on topic 5i23 does not see stand alone encoders
Can you check that the encoder signals get to the 5i23 card?
As I mentioned, this can be done by using halmeter or show hal configuration/watch on the GPIO pins
that the encoders connect to.
(you can find out which GPIO pins by looking at the dmesg list of pins)
- mariusl
07 Dec 2012 05:06 #27343
by mariusl
Regards
Marius
www.bluearccnc.com
I know where they are connected to and I used the Halmeter to see if I get any count.
This is the setup code for these encoders. Is this good enough or must I do more?
And this is in my INI file
# dual encoder functions
# --- FRONT_ENCODER ---
net Front_Encoder-position <= hm2_5i23.0.encoder.05.position
net Front_Encoder-count <= hm2_5i23.0.encoder.05.count
net Front_Encoder-velocity <= hm2_5i23.0.encoder.05.velocity
net Front_Encoder-reset <= hm2_5i23.0.encoder.05.reset
net Front_Encoder-index-enable <= hm2_5i23.0.encoder.05.index-enable
# --- BACK_ENCODER ---
net Back_Encoder-position <= hm2_5i23.0.encoder.06.position
net Back_Encoder-count <= hm2_5i23.0.encoder.06.count
net Back_Encoder-velocity <= hm2_5i23.0.encoder.06.velocity
net Back_Encoder-reset <= hm2_5i23.0.encoder.06.reset
net Back_Encoder-index-enable <= hm2_5i23.0.encoder.06.index-enable
# ------------- FRONT ENCODER ------------
setp hm2_5i23.0.encoder.05.counter-mode 0
setp hm2_5i23.0.encoder.05.filter 1
setp hm2_5i23.0.encoder.05.index-invert 0
setp hm2_5i23.0.encoder.05.index-mask 0
setp hm2_5i23.0.encoder.05.index-mask-invert 0
setp hm2_5i23.0.encoder.05.scale [ENC_F]ENCODER_SCALE
# ------------- BACK ENCODER -------------
setp hm2_5i23.0.encoder.06.counter-mode 0
setp hm2_5i23.0.encoder.06.filter 1
setp hm2_5i23.0.encoder.06.index-invert 0
setp hm2_5i23.0.encoder.06.index-mask 0
setp hm2_5i23.0.encoder.06.index-mask-invert 0
setp hm2_5i23.0.encoder.06.scale [ENC_B]ENCODER_SCALE
Regards
Marius
www.bluearccnc.com
07 Dec 2012 05:19 #27345
That should be fine. What I was asking was to verify that the encoder signal gets to the 5I23 card
The first step is to make sure both A/B encoder signals signals toggle at the 5I23 GPIO pins that connect
to these encoder signals
If this doesn't happen, you will need to trace the signal back from the encoder. --> 7I33 inputs --> flatcable --> 5I23 inputs
- mariusl
07 Dec 2012 05:33 #27347
by mariusl
Regards
Marius
www.bluearccnc.com
I scoped the signals from the encoders going into the 7i33. Bear in mind that all the other channels and functions on the same card is working OK. Well at least that there are signals present. I dont know if the order is correct, I will have to check.
Please confirm that I can connect an encoder by itself to a servo channel (no drive and motor).
Regards
Marius
www.bluearccnc.com
07 Dec 2012 05:36 #27348
Yes the encoder will work by itself
Can you _please_ check the GPIO pins as I asked?
- mariusl
07 Dec 2012 05:41 #27349
by mariusl
Regards
Marius
www.bluearccnc.com
I will check when I get to the machine again. Thanks for the help so far. Now that I know that it can be done, I am sure that I am going to find config problems.
Regards
Marius
www.bluearccnc.com
Time to create page: 0.134 seconds
