Mesa 7i77 and old Copley / Anilam amps
25 Dec 2012 00:28 #28013 by jj89074
I am retrofitting a cnc mill that had an Anilam controller with Copley velocity amps. The amps are a little different in that they use a "lockout" pin instead of an "enable" pin.
With nothing connected to the "lockout" pin, it stays high and the amp is enabled. The Anilam control did not even connect to this pin (pins 8 on the amps).
Connecting the amp's "lockout" pin to "com" (pulling it down) will disable the amp.
My question is: do I connect the ENAx- pins to "com" and the ENAx+ pins to "lockout" and somehow configure the 7i77 to act as normally open contacts when enabled and closed when disabled? How do I do this?
Thanks,
Jim
25 Dec 2012 00:41 - 25 Dec 2012 00:51 #28015 by PCW
Replied by PCW on topic Mesa 7i77 and old Copley / Anilam amps
For normally enabled amps I would just use a relay with a normally closed contact
that disables the drives until the relay is driven by a 7I77 field output.
I should add that any scheme that makes the OPTO enable outputs normally on
is not very safe as they would be off (drive enabled) if the 7I77 was not powered
Its very likely that the original control has a relay with normally closed contacts
for enabling the drives only when the relay is powered
Last edit: 25 Dec 2012 00:51 by PCW.
25 Dec 2012 00:50 #28016 by jj89074
Replied by jj89074 on topic Mesa 7i77 and old Copley / Anilam amps
Thanks for the quick reply and simple answer!
Moderators: PCWjmelson
Time to create page: 0.057 seconds
