USB Based FPGA Mesa Card will support LinuxCNC ?
06 Mar 2013 16:02 #30956 by 3kamalakkannan
USB Based FPGA Mesa Card will support LinuxCNC ? was created by 3kamalakkannan
Hi friends,
Do you know about support for usb based FPGA.
7I43H - Anything I/O High speed USB - 400K FPGA - 48 I/O
www.mesanet.com/pdf/parallel/7i43ds.pdf
But I was seen some of the forums USB is not real-time performance.I am confused :( .Can you anyone explain to me.
Advance thank you :)
06 Mar 2013 16:07 #30957 by cmorley
The 7i43 with USB is not supported in standard linuxcnc.
only the parallel port 7i43 is supported.
A fork of linuxcnc has used the 7i43 through USB - so it is possible - with limitations.
The following user(s) said Thank You: 3kamalakkannan
Moderators: PCWjmelson
Time to create page: 0.048 seconds
