3 axis mill hardware setup
- mort
05 Jun 2013 20:46 #35282
by mort
3 axis mill hardware setup was created by mort
I am in the process of converting a manual Bridgeport mill to cnc. It will be using 3 brushless 3 phase dc motors with TTL encoders. So far based on my research in these forums, I have determined that I need at least the 5I25, 7I85, 7I84, and 3x 8I20 drives. I would also like to control the spindle with a VFD and add a 4th axis at a later date. Should this cover everything as far as control hardware goes?
Also, what benefit if any would there be with going with the 5I23, 5I22, or 5I20 cards?
I wanted to make sure this setup sounds correct before purchasing anything. Thanks for any help!
- Thank you received: 4988
06 Jun 2013 06:00 #35300
I can't help feeling that Mesa should consider making a 6pin-Phoenix to RJ45 adaptor board to simplify wiring smart-serial devices. That does rather assume the existence of a PCB-mounted plug of that type though.
Note that it is relatively easy to control certain VFDs with Modbus and the serial port or ethernet. (Or a USB to RS485 converter)
Replied by andypugh on topic 3 axis mill hardware setup
Do the motors have Hall-sensors, or are the encoders the 6-channel type?I am in the process of converting a manual Bridgeport mill to cnc. It will be using 3 brushless 3 phase dc motors with TTL encoders.
You probably just didn't mention it, but the 8i20 needs at last 50V.So far based on my research in these forums, I have determined that I need at least the 5I25, 7I85, 7I84, and 3x 8I20 drives. I would also like to control the spindle with a VFD and add a 4th axis at a later date. Should this cover everything as far as control hardware goes?
No real advantage, unless the available cards suit your requirements better. My similar conversion is using the 5i23 because I needed the Resolver daughter board (and, also, I started the conversion before the 5i25 was launched)Also, what benefit if any would there be with going with the 5I23, 5I22, or 5I20 cards?
- Thank you received: 5254
06 Jun 2013 06:42 #35304
Replied by PCW on topic 3 axis mill hardware setup
For 7I85 --> 8I20 wiring, a cat 5 cable with 8 pin 3.5 mm Phoenix type
connector on one end and RJ45 plug on the other is used.
We can supply these or they can be made by cutting a standard network
cable in 1/2 and terminating the wires (preferably with ferrules)
in a Phoenix type 3.5 mm plug
- mort
06 Jun 2013 07:17 #35312
by mort
Replied by mort on topic 3 axis mill hardware setup
Yes the motors have hall feedback sensors. The encoders are Heidenhain Rod encoders. The motors are 100 vdc- I already have separate power supplies as well. Thanks for the help.
Time to create page: 0.058 seconds
