Dave,
Thanks for the feedback, I've been running my HAL file as generated from PNCCONFIG. The resolver section is as shown below (full hal/ini attached) . Everything was similar to your post with the exception of the => pid.0.feedback so I added that as pid.x.feedback to match my naming convention and it didn't fix anything. Because I'm trying everything I also swapped all my pid.x to pid.0 etc and tried it that way, no luck. Let me know if you have any other things to try. I did re-verify the resolver signals at the 7i49 and they look good. Thanks,
-Scott
loadrt hm2_7i43 config="firmware=hm2/7i43-4/SVRM6.BIT num_encoders=0 num_pwmgens=3 num_3pwmgens=0 num_stepgens=0 num_resolvers=3"
setp hm2_7i43.0.pwmgen.pwm_frequency 24000
setp hm2_7i43.0.pwmgen.pdm_frequency 6000000
setp hm2_7i43.0.watchdog.timeout_ns 10000000
loadrt pid names=pid.x,pid.z,pid.s
# ---Resolver feedback signals/setup---
setp hm2_7i43.0.resolver.00.velocity-scale 1 # mptor speed in RPS
setp hm2_7i43.0.resolver.00.scale [AXIS_0]RESOLVER_SCALE
net x-pos-rawcounts <= hm2_7i43.0.resolver.00.rawcounts
net x-pos-fb <= hm2_7i43.0.resolver.00.position => pid.x.feedback
net x-vel-fb <= hm2_7i43.0.resolver.00.velocity
net x-pos-fb => axis.0.motor-pos-fb
net x-index-enable axis.0.index-enable <=> hm2_7i43.0.resolver.00.index-enable
