ppmc configs????
- jlviloria
- Thank you received: 12
24 Jun 2013 23:18 #35995
by jlviloria
ppmc configs???? was created by jlviloria
greetings to all.
I'm starting my settings with PPMC, I MDX650A roland retrofit a router, with 4 axis.
is my first time with PPMC,
I have two universal stepper, 4 PWM Brushless Servo Amplifier, all connectors for operation.
first thing I did was get the parallel port. check the forum and found a way to have a diagnosis of it is the following.
05:00.0 Parallel controller: NetMos Technology PCI 9865 Multi-I/O Controller (prog-if 03)
Subsystem: Device a000:2000
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 32, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 11
Region 0: I/O ports at d010
Region 1: I/O ports at d000
Region 2: Memory at fb101000 (32-bit, non-prefetchable) [size=4K]
Region 4: Memory at fb100000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
then download the program ppmc diagnosis, and I threw it.
with the feeding of 12 VDC. no more nothing connected.
cnc@cnc:~$ sudo ./ppmcdiags d010 bus
diags ppmc test program V4.2 5/5/2013
io addr = d010
parport addr 0xd010
Bus Map
Board Addr Type Ver.
0 Unknown 55
1 Encoder 0
2 DAC-16 f
3 DIO f
4 Univ. Stepper f
6 Unknown 6f
7 Unknown 7f
8 Unknown 8f
9 Unknown 9f
a Unknown af
b Unknown bf
c Unknown cf
d Unknown df
e Unknown ef
f No Board ff
cnc@cnc:~$
really do not understand.
There are currently no led on, I have just connected a card (UPC), I want to know what happens, will the parallel port is not supported, as I can be sure this is right or wrong?
Further to this, this card has a dip switch, this ON, 1, 2 and 10.
truth does not quite understand the procedure to know if my card is ready to start configuring.
thanks,
Jorge
io addr = d010
parport addr 0xd010
Bus Map
0 Unknown 55
1 Encoder 0
2 DAC-16 f
3 DIO f
4 Univ. Stepper f
6 Unknown 6f
7 Unknown 7f
8 Unknown 8f
9 Unknown 9f
a Unknown af
b Unknown bf
c Unknown cf
d Unknown df
e Unknown ef
f No Board ff
cnc@cnc:~$
thanks,
Jorge
- jlviloria
24 Jun 2013 23:24 #35998
by jlviloria
Replied by jlviloria on topic ppmc configs????
run the sudo. / ppmcdiags d010 Commtest
12982 cycle test, axis 1 was b7 e2 a8 / should be e2 b6 a8
12986 cycle test, axis 2 was 50 61 26 / should be 4f 61 26
13000 test cycles, 1173 errors
13010 cycle test, axis 3 was a2 b8 13 / should be a1 b8 13
13016 cycle test, axis 0 2e faith was ce / should be 2d faith ce
13039 cycle test, axis was 0 79 79 24 / should be 78 79 24
- jmelson
- Thank you received: 159
25 Jun 2013 10:23 #36019
by jmelson
the PC and the UPC boards are getting out of sync. I also see
a two-bit error at 13010, where an "a1" was read as "a2".
Are you using the parallel cable that I supplied with the unit?
You must use an IEEE-1284 cable, standard 25-pin cables don't
work at all. I think you indicated you were using a NetMos
parallel card, some older NetMos cards did not work at all
in EPP mode. I can't say whether your card is good or not,
all I know is Dell and Intel on-motherboard ports work very well, and
SIIG PCI cards work well.
Jon
Replied by jmelson on topic ppmc configs????
This is not good at all! The errors show some bytes OK, so it looks likerun the sudo. / ppmcdiags d010 Commtest
Jon
- jmelson
25 Jun 2013 10:26 #36020
by jmelson
LinuxCNC driver is called "ppmc", it actually serves 3 different devices,
the PPMC and the universal PWM and stepper controllers.
Jon
Just to be clear, you have two Universal PWM Controllers. Although thegreetings to all.
Jorge
Jon
- jlviloria
25 Jun 2013 20:16 - 25 Jun 2013 20:17 #36039
by jlviloria
Jon, thanks for your answer.
I consult with my suppliers, and do not handle SIIG brand.
This is the parallel port I'm using, clearly says that working in EPP mode.
There will be parallel port settings? lei on this page you need to run something in C, to set to EPP. bearings would know as this?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Startech
thanks.
Jorge
thanks.
Jorge
Last edit: 25 Jun 2013 20:17 by jlviloria.
- jlviloria
27 Jun 2013 00:27 - 27 Jun 2013 19:52 #36099
by jlviloria
Hello,
A PCI Express, may serve to communication with FPGA systems???
thanks,
Jorge Viloria
thanks,
Jorge Viloria
Last edit: 27 Jun 2013 19:52 by jlviloria.
Time to create page: 0.061 seconds
