Best combination for 5i25?
- green751
- Visitor
12 Jul 2013 01:02 #36574
by green751
Best combination for 5i25? was created by green751
Hi, all;
I have a CNC mill that currently has 3 axes - X/Y/Z, plus it will soon have a servo spindle. All of these axes have encoders.
I also have a manual pulse generator I'd like to add, that's also an encoder.
Finally, I have a DDR servo that has resolver feedback. If I had a cable for this I could get encoder output from the drive, but they're hard to find, and supposedly the accuracy of the resolver depends on using the original cable, which I don't have.
I'm picking out a new driver board from Mesa to replace the 5i20/7i31/7i33 combo I have now. I'm thinking the 5i25/7i77 combo with cable will work fine, but I'm looking for a simple way to add the resolver feedback. Is a 7i49 my only option for that, or could I do it some other way?
Erik
Erik
- Thank you received: 5255
12 Jul 2013 02:06 #36579
Replied by PCW on topic Best combination for 5i25?
If the drive has resolver feedback (going to the drive) there is likely no easy way to interface to it and the drive other than using the drives emulated encoder output. This is because most resolver interfaces generate the excitation waveform and expect the sine/cos signals from the resolver to be in phase with this reference waveform. (and the drive does the same)
Time to create page: 0.049 seconds
