Mesa 3x20 / 7i49 / 7i33 / 8i20 / 7i44 / 7i37
- buster142
20 Jul 2013 16:41 #36820
by buster142
Mesa 3x20 / 7i49 / 7i33 / 8i20 / 7i44 / 7i37 was created by buster142
Hi all,
I'd like to build a milling machine. so i bought the following components from Mesa
3x20 6i68 Anything io card ( 1k )
7i49 6 channel resolver interface
7i33 Quad Analog servo interface
8i20 2200W 3 Phase Amplifier
7i44 Eight Channel RS-422/485
7i37 Isolated I/O card
Which firmware should i use? Do I need to build one? How can i configure the Xilinx ISE to compile the required hm2 modules into a .bin file?
Micha
Micha
- Thank you received: 5255
21 Jul 2013 01:02 #36836
Replied by PCW on topic Mesa 3x20 / 7i49 / 7i33 / 8i20 / 7i44 / 7i37
I can make a configuration for this on Monday
Its possible to do this by downloading the hm2 source from
Mesa and compiling but since this is a new configuration
and a pinout file must be built its a fair amount of work
- buster142
21 Jul 2013 01:32 #36838
by buster142
Replied by buster142 on topic Mesa 3x20 / 7i49 / 7i33 / 8i20 / 7i44 / 7i37
Thanks a lot! I try it already by myself, but i don't succeed. I've downloaded the Xilinx web pack 13.4 and the hm2 source from git.linuxcnc.org. Now i'm able to build the SV24S.bit file but nothing more...
I think i'll wait till monday
thanks again
Micha
thanks again
Micha
- Thank you received: 4988
22 Jul 2013 19:23 #36884
That is quite a lot of hardware. I am wondering why you need the 7i49 _and_ the 7i33?
Do you have a mixture of resolver-servos and encoder-servos?
Replied by andypugh on topic Mesa 3x20 / 7i49 / 7i33 / 8i20 / 7i44 / 7i37
- buster142
22 Jul 2013 20:49 #36887
by buster142
Cause I've a lot of different Servomotors and ServoAmps. I'm not sure which combination of Motor and Amp is the best one. My prefered choice would be a Rexroth Indradrive... but LinuxCNC have no SERCOS support
22 Jul 2013 20:56 #36889
I don't know if that is necessarily true.
www.bitmuster.org/projects/emc.html
23 Jul 2013 08:05 #36924
freeby.mesanet.com/sssvstrm8_10.bit
Should be close
Didnt have time to make pin or xml files yet but:pinout is
6I68 connectors
P2 7I33
P3 7I49
P4 7I44
(others are GPIO only)
Should be close
6I68 connectors
P2 7I33
P3 7I49
P4 7I44
The following user(s) said Thank You: buster142
- buster142
24 Jul 2013 02:33 #36953
by buster142
Big Thanks!
I'll get the 7i33 and the 7i49 this weekend... The smartSerial connection to the 8i20 is working. Is it possible to drive the motor without any encoder/resolver?
24 Jul 2013 03:18 #36956
Sort of, you can run the motor in step motor mode which is wildly inefficient
and likely to overheat the motor/8I20 if done for too long. This mode is used
in some of BLDCs non- HALL rotor position sensing start-up methods
Time to create page: 0.087 seconds
