Best way to add 4 analog +/-10V to 5i20/7i33/7i37?
- green751
- Visitor
01 Sep 2013 04:36 #38336
by green751
Best way to add 4 analog +/-10V to 5i20/7i33/7i37? was created by green751
Hi, all;
I've just about gotten to the point budget wise I can buy some additional servo channels to play with. My 5i20/7i33/7i37 combo works well, but it has only four analog outputs. This is an issue because for the next incarnation of my mill I want to use both a servo spindle and a 4th axis, totalling 5 servos to control. Additionally, I'd like to try using the bldc module for servo control, which means for 3 axes I need two analog outputs per axis. To make things more interesting I have an MPG I'd like to connect to an encoder input.
Since the 5i20 has three 50 pin connectors, could I just add another 7i33 and use it with the two existing cards (three daughter cards total)? If it works and I did, would there be limitations of any kind?
I'd pretty much settled on buying a 5i25+7i77 combo, but if I can do something cheaper I can do it sooner. Also, even for that combo I'd probably need something like a 7i83 in addition to the 7i77 to get enough servo channels to play with, which drives the price up even more. Hence I'm wondering if there's a cheaper way to do it.
Alternatively if anyone can suggest the cheapest way to get 8-10 +/-10V analog outputs with 6 quadrature encoder inputs and at least 16 digital in and 16 digital out, I'd like to hear it.
Thanks for any info,
Erik
Erik
- Thank you received: 5255
01 Sep 2013 08:41 #38337
Replied by PCW on topic Best way to add 4 analog +/-10V to 5i20/7i33/7i37?
Yes, you can simply add another 7I33 to get 4 more encoder inputs.
The only limitation of this card setup is there is no more I/O expansion available
There are a few other options for more I/O: for example you could add a 7I52 which would
give you 6 more encoder inputs and 6 sserial channels for I/O and analog expansion
(at a cost of course)
- green751
- Visitor
01 Sep 2013 22:14 #38365
by green751
Replied by green751 on topic Best way to add 4 analog +/-10V to 5i20/7i33/7i37?
Thanks. I'm thinking what I may do is just add the 7i33 now and start experimenting, then when funds permit swap the whole board set out for something with more ports. I could use another set of Mesa cards for another project anyway, and likely it'll need less I/O than my mill does...
Erik
Erik
Time to create page: 0.052 seconds
