What Mesa cards to use
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
10 Sep 2013 21:10 #38618 by mariusl
What Mesa cards to use was created by mariusl
Hi
Has anyone had any experience with the MiniBravo 60 servo motor drives. I need to know if I can use them with Mesa cards?
Regards
Marius
www.bluearccnc.com
10 Sep 2013 21:33 #38621 by andypugh
Replied by andypugh on topic What Mesa cards to use
No, I have none.
www.dgjunzhong.com/Upload/PicFiles/2011.9.7_18.15.54_6753.pdf
Suggest absolutely standard +/-10V drive. They will run from any of the Mesa servo drives.
The 5i25 / 7i77 combo would work well, but there may be reasons to choose other cards if you need a lot more IO, or resolvers, or that sort of thing.
  • mariusl
  • Platinum Member
  • Platinum Member
10 Sep 2013 21:48 #38624 by mariusl
Replied by mariusl on topic What Mesa cards to use
Thanks Andy, that is half the problem solved. The feedback is still a bit of an issue as they have an encoder fitted and the drive does not share that information. I have to find a way around that.
Regards
Marius
www.bluearccnc.com
10 Sep 2013 22:09 #38625 by andypugh
You can probably just wire the encoders to both the drive and the Mesa card.
Moderators: PCWjmelson
Time to create page: 0.062 seconds
