5i25 7i77 logic input
  • emcPT
  • emcPT's Avatar Topic Author
  • Platinum Member
  • Platinum Member
03 Dec 2013 16:26 - 03 Dec 2013 17:23 #41304 by emcPT
5i25 7i77 logic input was created by emcPT
Hello.
In a 5i25 7i77 combo, with field bus at 24V for most of the IO (and I want to keep it like this), I have the need to receive status signals from my servos, that are only available in 5V.
Although I have almost sure that there is no way to use directly the 5V without transforming them in 24V, I am asking, as it could exist a easy way to use them directly without creating another board for matting the signals.
In the total we have x6 logic 5V signals from the servos, that must be used.
UPDATE:
It looks that I can use the available parallel port type present on the 5i25 (P2 connector) for this. I did not connected anything hoping for confirmation from the forum.
Thank you.
Last edit: 03 Dec 2013 17:23 by emcPT.
03 Dec 2013 19:46 #41308 by cgc
Replied by cgc on topic 5i25 7i77 logic input
Hello,
maybe this thread can help you.
www.linuxcnc.org/emc2/index.php/italian/...ield-input-threshold
Frank
  • emcPT
  • Platinum Member
  • Platinum Member
03 Dec 2013 19:58 #41309 by emcPT
Replied by emcPT on topic 5i25 7i77 logic input
Thank you, but I need at least 6.
The 7i77 board can only read 4 analog inputs, so it is not a solution for now.
  • green751
  • green751's Avatar
  • Visitor
  • Visitor
03 Dec 2013 22:55 #41311 by green751
Replied by green751 on topic 5i25 7i77 logic input
I'm guessing you could use a 7i87 or a 7i70 for this, but that's more expensive than just using a circuit.
There are also converters for this: www.calex.com/cis549.html
One cheap solution might be to use a regular parallel port on your control PC... assuming all you want is sensing of a digital signal.
I think if it was me I'd probably just use some DIN rail mount optocouplers for this. 5v input, 24v to field supply and the 7i77 output.
Erik
  • emcPT
  • Platinum Member
  • Platinum Member
03 Dec 2013 23:05 #41313 by emcPT
I prefer to use the current hardware.
The optocouplers are a solution, but maybe I can use the P2 in the 5i25, and no extra hardware or unnecessary confusion will exist. Can I safely use it?
03 Dec 2013 23:05 #41314 by PCW
Replied by PCW on topic 5i25 7i77 logic input
The 7I77 has the hardware to do this but I'll
have to check if the firmware has the per pin
input threshold setting option supported yet
  • emcPT
  • Platinum Member
  • Platinum Member
03 Dec 2013 23:13 #41315 by emcPT
I will wait then.
And the P2 on the 5i25 is not an option?
03 Dec 2013 23:24 - 03 Dec 2013 23:28 #41316 by PCW
P2 signals are usable with a couple limitations. P2 signals are just like parallel port signals: TTL levels and high speed. This means:
1. They are susceptible to high frequency noise, so you may need to use the debounce component
2. They are not protected from voltage spikes (anything over 7V or less than about -0.7V for a very short time will damage the 5I25
Both of these problems can be eliminated by using a breakout board of some kind (say the Mesa 7I75)
Or you can just be very careful with what you connect to the P2 pins :-)
Last edit: 03 Dec 2013 23:28 by PCW.
  • emcPT
  • Platinum Member
  • Platinum Member
04 Dec 2013 00:12 #41318 by emcPT
Ok, I will not use the P2 of the 5i25 for extended safety.
Can you (PCW) confirm if the individual pin threshold is implemented?
Thank you
04 Dec 2013 00:49 #41319 by PCW
I can tommorow
Moderators: PCWjmelson
