7i77 drive enables
12 Dec 2013 10:04 #41532 by tjones
7i77 drive enables was created by tjones
I am trying to set up the 7i77. I got everything plugged in. Did a battery test on my amplifiers and my servos move. The problem I have is when i go to jog an axis i does nothing. I have my following error turned up to about a half an inch so I am not running into that error. I am not using the Aout0 in the TB5 connector. I am wondering if that needs to be plugged it for it to work. I have try setting my "P" Value up in the Servo Calibration. I just hooked at oscilloscope and I saw nothing coming form the 7i77.
Thanks,
Tosh Jones
12 Dec 2013 10:31 #41533 by PCW
Replied by PCW on topic 7i77 drive enables
The AOUT0 pin is the first analog output so must be connected to your drives analog input to work. The ENA0+ and ENA0- pins are the enable signals for this drive (The ENA signals are a normally open OPTO switch that is "on" when the analog outputs are enabled
Moderators: PCWjmelson
Time to create page: 0.059 seconds
