MESA 5I22 1,5
- tld70
I try to start the sample in LINUXCNC 5i22 big.
The 5i22 is plugged in and after start I become follow errors:
Does somebody ha a idea?
I run Master in Ubuntu 12.04.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4.55-rtai-2/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.0-pre0-5183-g56fdc0e
Machine configuration directory is '/home/thomas/linuxcnc/configs/by_interface.mesa.hm2-servo'
Machine configuration file is '5i22-big.ini'
INIFILE=/home/thomas/linuxcnc/configs/by_interface.mesa.hm2-servo/5i22-big.ini
PARAMETER_FILE=hm2-servo.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
io started
halcmd loadusr io started
Killing task linuxcncsvr, PID=3892
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-3.4.55-rtai-2/modules/linuxcnc/hm2_pci.ko': -1 Unknown symbol in module
hm2-servo.hal:46: exit value: 1
hm2-servo.hal:46: insmod failed, returned -1
See the output of 'dmesg' for more information.
3892
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
Linux version 3.4.55-rtai-2 (root@precise-x86) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Sun Dec 15 23:40:48 MST 2013
BIOS-provided physical RAM map:
BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 000000007fee0000 (usable)
BIOS-e820: 000000007fee0000 - 000000007fee3000 (ACPI NVS)
BIOS-e820: 000000007fee3000 - 000000007fef0000 (ACPI data)
BIOS-e820: 000000007fef0000 - 000000007ff00000 (reserved)
BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
SMBIOS 2.3 present.
DMI: System manufacturer System Product Name/M2N-E SLI, BIOS ASUS M2N-E SLI ACPI BIOS Revision 0401 10/04/2006
e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
last_pfn = 0x7fee0 max_arch_pfn = 0x100000
MTRR default type: uncachable
MTRR fixed ranges enabled:
00000-9FFFF write-back
A0000-BFFFF uncachable
C0000-C7FFF write-protect
C8000-FFFFF uncachable
MTRR variable ranges enabled:
0 base 0000000000 mask FF80000000 write-back
1 base 007FF00000 mask FFFFF00000 uncachable
2 disabled
3 disabled
4 disabled
5 disabled
6 disabled
7 disabled
x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
found SMP MP-table at [c00f5410] f5410
initial memory mapped : 0 - 01c00000
Base memory trampoline at [c009e000] 9e000 size 4096
init_memory_mapping: 0000000000000000-00000000377fe000
0000000000 - 0000400000 page 4k
0000400000 - 0037400000 page 2M
0037400000 - 00377fe000 page 4k
kernel direct mapping tables up to 0x377fdfff @ [mem 0x01bf8000-0x01bfffff]
RAMDISK: 3668a000 - 3733d000
ACPI: RSDP 000f6ed0 00024 (v02 Nvidia)
ACPI: XSDT 7fee30c0 00044 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
ACPI: FACP 7feeb280 000F4 (v03 Nvidia AWRDACPI 42302E31 AWRD 00000000)
ACPI: DSDT 7fee3240 08000 (v01 NVIDIA AWRDACPI 00001000 MSFT 0100000E)
ACPI: FACS 7fee0000 00040
ACPI: HPET 7feeb480 00038 (v01 Nvidia AWRDACPI 42302E31 AWRD 00000098)
ACPI: MCFG 7feeb500 0003C (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
ACPI: APIC 7feeb3c0 0007C (v01 Nvidia AWRDACPI 42302E31 AWRD 00000000)
ACPI: Local APIC address 0xfee00000
1158MB HIGHMEM available.
887MB LOWMEM available.
mapped low ram: 0 - 377fe000
Zone PFN ranges:
DMA 0x00000010 -> 0x00001000
Normal 0x00001000 -> 0x000377fe
HighMem 0x000377fe -> 0x0007fee0
Movable zone start PFN for each node
Early memory PFN ranges
0: 0x00000010 -> 0x0000009f
0: 0x00000100 -> 0x0007fee0
On node 0 totalpages: 523887
free_area_init_node: node 0, pgdat c160d9c0, node_mem_map f568a200
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 3951 pages, LIFO batch:0
Normal zone: 1744 pages used for memmap
Normal zone: 221486 pages, LIFO batch:31
HighMem zone: 2318 pages used for memmap
HighMem zone: 294356 pages, LIFO batch:31
Using APIC driver default
ACPI: PM-Timer IO Port: 0x4008
ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
IOAPIC[0]: apic_id 2, version 17, address 0xfec00000, GSI 0-23
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
ACPI: INT_SRC_OVR (bus 0 bus_irq 14 global_irq 14 high edge)
ACPI: INT_SRC_OVR (bus 0 bus_irq 15 global_irq 15 high edge)
ACPI: IRQ0 used by override.
ACPI: IRQ2 used by override.
ACPI: IRQ9 used by override.
ACPI: IRQ14 used by override.
ACPI: IRQ15 used by override.
Using ACPI (MADT) for SMP configuration information
ACPI: HPET id: 0x10de8201 base: 0xfefff000
SMP: Allowing 2 CPUs, 0 hotplug CPUs
nr_irqs_gsi: 40
Allocating PCI resources starting at 7ff00000 (gap: 7ff00000:60100000)
setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
PERCPU: Embedded 17 pages/cpu @f77cf000 s47552 r0 d22080 u69632
pcpu-alloc: s47552 r0 d22080 u69632 alloc=17*4096
pcpu-alloc: [0] 0 [0] 1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519793
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4.55-rtai-2 root=UUID=e9c54f92-a1e2-4b3b-b051-392e539c069a ro quiet splash vt.handoff=7
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Initializing CPU#0
Initializing HighMem for node 0 (000377fe:0007fee0)
Memory: 2057776k/2096000k available (4612k kernel code, 37772k reserved, 1613k data, 544k init, 1186696k highmem)
virtual kernel memory layout:
fixmap : 0xfff18000 - 0xfffff000 ( 924 kB)
pkmap : 0xff800000 - 0xffc00000 (4096 kB)
vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
.init : 0xc1615000 - 0xc169d000 ( 544 kB)
.data : 0xc148113d - 0xc1614580 (1613 kB)
.text : 0xc1000000 - 0xc148113d (4612 kB)
Checking if this processor honours the WP bit even in supervisor mode...Ok.
SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Preemptible hierarchical RCU implementation.
Dump stacks of tasks blocking RCU-preempt GP.
NR_IRQS:2304 nr_irqs:512 16
CPU 0 irqstacks, hard=f5008000 soft=f500a000
Extended CMOS year: 2000
Interrupt pipeline (release #3)
spurious 8259A interrupt: IRQ7.
Console: colour dummy device 80x25
console [tty0] enabled
hpet clockevent registered
Fast TSC calibration using PIT
Detected 2211.236 MHz processor.
Marking TSC unstable due to TSCs unsynchronized
Calibrating delay loop (skipped), value calculated using timer frequency.. 4422.47 BogoMIPS (lpj=2211236)
pid_max: default: 32768 minimum: 301
Security Framework initialized
AppArmor: AppArmor initialized
Mount-cache hash table entries: 512
CPU: Physical Processor ID: 0
CPU: Processor Core ID: 0
mce: CPU supports 5 MCE banks
LVT offset 0 assigned for vector 0xf9
using AMD E400 aware idle routine
Freeing SMP alternatives: 20k freed
ACPI: Core revision 20120320
Enabling APIC mode: Flat. Using 1 I/O APICs
..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
CPU0: AMD Athlon(tm) 64 X2 Dual Core Processor 4200+ stepping 02
Performance Events: AMD PMU driver.
... version: 0
... bit width: 48
... generic registers: 4
... value mask: 0000ffffffffffff
... max period: 00007fffffffffff
... fixed-purpose events: 0
... event mask: 000000000000000f
CPU 1 irqstacks, hard=f5088000 soft=f508a000
Booting Node 0, Processors #1 Ok.
Initializing CPU#1
Brought up 2 CPUs
Total of 2 processors activated (8844.72 BogoMIPS).
devtmpfs: initialized
EVM: security.selinux
EVM: security.SMACK64
EVM: security.capability
dummy:
NET: Registered protocol family 16
EISA bus registered
node 0 link 0: io port [8000, ffff]
TOM: 0000000080000000 aka 2048M
node 0 link 0: mmio [a0000, bffff]
node 0 link 0: mmio [feb00000, fec0ffff]
node 0 link 0: mmio [80000000, dfffffff]
node 0 link 0: mmio [f0000000, fe02ffff]
node 0 link 0: mmio [e0000000, e05fffff]
bus: [00, 05] on node 0 link 0
bus: 00 index 0 [io 0x0000-0xffff]
bus: 00 index 1 [mem 0x000a0000-0x000bffff]
bus: 00 index 2 [mem 0xfe030000-0xffffffff]
bus: 00 index 3 [mem 0x80000000-0xefffffff]
bus: 00 index 4 [mem 0xf0000000-0xfe02ffff]
ACPI: bus type pci registered
PCI: Using configuration type 1 for base access
bio: create slab <bio-0> at 0
ACPI: Added _OSI(Module Device)
ACPI: Added _OSI(Processor Device)
ACPI: Added _OSI(3.0 _SCP Extensions)
ACPI: Added _OSI(Processor Aggregator Device)
ACPI: EC: Look up EC in DSDT
ACPI: Interpreter enabled
ACPI: (supports S0 S5)
ACPI: Using IOAPIC for interrupt routing
PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-05])
pci_root PNP0A08:00: host bridge window [io 0x0000-0x03af] (ignored)
pci_root PNP0A08:00: host bridge window [io 0x03e0-0x0cf7] (ignored)
pci_root PNP0A08:00: host bridge window [io 0x4c00-0x4c7f] (ignored)
pci_root PNP0A08:00: host bridge window [io 0x8000-0xffff] (ignored)
pci_root PNP0A08:00: host bridge window [io 0x03b0-0x03df] (ignored)
pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
pci_root PNP0A08:00: host bridge window [mem 0x80000000-0xdfffffff] (ignored)
pci_root PNP0A08:00: host bridge window [mem 0xf0000000-0xfe02ffff] (ignored)
pci_root PNP0A08:00: host bridge window [mem 0xfeb00000-0xfebfffff] (ignored)
PCI: root bus 00: hardware-probed resources
PCI host bridge to bus 0000:00
pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
pci_bus 0000:00: root bus resource [mem 0xfe030000-0xffffffff]
pci_bus 0000:00: root bus resource [mem 0x80000000-0xefffffff]
pci_bus 0000:00: root bus resource [mem 0xf0000000-0xfe02ffff]
pci 0000:00:00.0: [10de:005e] type 00 class 0x058000
pci 0000:00:01.0: [10de:0050] type 00 class 0x060100
pci 0000:00:01.1: [10de:0052] type 00 class 0x0c0500
pci 0000:00:01.1: reg 10: [io 0xfc00-0xfc1f]
pci 0000:00:01.1: reg 20: [io 0x4c00-0x4c3f]
pci 0000:00:01.1: reg 24: [io 0x4c40-0x4c7f]
pci 0000:00:01.1: PME# supported from D3hot D3cold
pci 0000:00:02.0: [10de:005a] type 00 class 0x0c0310
pci 0000:00:02.0: reg 10: [mem 0xfe02f000-0xfe02ffff]
pci 0000:00:02.0: supports D1 D2
pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:02.1: [10de:005b] type 00 class 0x0c0320
pci 0000:00:02.1: reg 10: [mem 0xfeb00000-0xfeb000ff]
pci 0000:00:02.1: supports D1 D2
pci 0000:00:02.1: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:06.0: [10de:0053] type 00 class 0x01018a
pci 0000:00:06.0: reg 20: [io 0xe800-0xe80f]
pci 0000:00:07.0: [10de:0054] type 00 class 0x010185
pci 0000:00:07.0: reg 10: [io 0x09f0-0x09f7]
pci 0000:00:07.0: reg 14: [io 0x0bf0-0x0bf3]
pci 0000:00:07.0: reg 18: [io 0x0970-0x0977]
pci 0000:00:07.0: reg 1c: [io 0x0b70-0x0b73]
pci 0000:00:07.0: reg 20: [io 0xd400-0xd40f]
pci 0000:00:07.0: reg 24: [mem 0xfe02c000-0xfe02cfff]
pci 0000:00:08.0: [10de:0055] type 00 class 0x010185
pci 0000:00:08.0: reg 10: [io 0x09e0-0x09e7]
pci 0000:00:08.0: reg 14: [io 0x0be0-0x0be3]
pci 0000:00:08.0: reg 18: [io 0x0960-0x0967]
pci 0000:00:08.0: reg 1c: [io 0x0b60-0x0b63]
pci 0000:00:08.0: reg 20: [io 0xc000-0xc00f]
pci 0000:00:08.0: reg 24: [mem 0xfe02b000-0xfe02bfff]
pci 0000:00:09.0: [10de:005c] type 01 class 0x060401
pci 0000:00:0a.0: [10de:0057] type 00 class 0x068000
pci 0000:00:0a.0: reg 10: [mem 0xfe02a000-0xfe02afff]
pci 0000:00:0a.0: reg 14: [io 0xbc00-0xbc07]
pci 0000:00:0a.0: supports D1 D2
pci 0000:00:0a.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:0b.0: [10de:005d] type 01 class 0x060400
pci 0000:00:0b.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:0c.0: [10de:005d] type 01 class 0x060400
pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:0d.0: [10de:005d] type 01 class 0x060400
pci 0000:00:0d.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:0e.0: [10de:005d] type 01 class 0x060400
pci 0000:00:0e.0: PME# supported from D0 D1 D2 D3hot D3cold
pci 0000:00:18.0: [1022:1100] type 00 class 0x060000
pci 0000:00:18.1: [1022:1101] type 00 class 0x060000
pci 0000:00:18.2: [1022:1102] type 00 class 0x060000
pci 0000:00:18.3: [1022:1103] type 00 class 0x060000
pci 0000:01:01.0: [1106:3044] type 00 class 0x0c0010
pci 0000:01:01.0: reg 10: [mem 0xfdfff000-0xfdfff7ff]
pci 0000:01:01.0: reg 14: [io 0xac00-0xac7f]
pci 0000:01:01.0: supports D2
pci 0000:01:01.0: PME# supported from D2 D3hot D3cold
pci 0000:01:06.0: [10b5:9054] type 00 class 0x068000
pci 0000:01:06.0: reg 10: [mem 0xfdffe000-0xfdffe0ff]
pci 0000:01:06.0: reg 14: [io 0xa800-0xa8ff]
pci 0000:01:06.0: reg 18: [io 0xa400-0xa4ff]
pci 0000:01:06.0: reg 1c: [mem 0xfdfe0000-0xfdfeffff]
pci 0000:01:06.0: reg 30: [mem 0xfdfc0000-0xfdfcffff pref]
pci 0000:01:07.0: [10b5:9054] type 00 class 0x068000
pci 0000:01:07.0: reg 10: [mem 0xfdffd000-0xfdffd0ff]
pci 0000:01:07.0: reg 14: [io 0xa000-0xa0ff]
pci 0000:01:07.0: reg 18: [io 0x9c00-0x9cff]
pci 0000:01:07.0: reg 1c: [mem 0xfdfd0000-0xfdfdffff]
pci 0000:01:07.0: reg 30: [mem 0xfdfc0000-0xfdfcffff pref]
pci 0000:00:09.0: PCI bridge to [bus 01-01] (subtractive decode)
pci 0000:00:09.0: bridge window [io 0x9000-0xafff]
pci 0000:00:09.0: bridge window [mem 0xfdf00000-0xfdffffff]
pci 0000:00:09.0: bridge window [io 0x0000-0xffff] (subtractive decode)
pci 0000:00:09.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
pci 0000:00:09.0: bridge window [mem 0xfe030000-0xffffffff] (subtractive decode)
pci 0000:00:09.0: bridge window [mem 0x80000000-0xefffffff] (subtractive decode)
pci 0000:00:09.0: bridge window [mem 0xf0000000-0xfe02ffff] (subtractive decode)
pci 0000:00:0b.0: PCI bridge to [bus 02-02]
pci 0000:00:0c.0: PCI bridge to [bus 03-03]
pci 0000:00:0d.0: PCI bridge to [bus 04-04]
pci 0000:05:00.0: [10de:0392] type 00 class 0x030000
pci 0000:05:00.0: reg 10: [mem 0xfa000000-0xfaffffff]
pci 0000:05:00.0: reg 14: [mem 0xd0000000-0xdfffffff 64bit pref]
pci 0000:05:00.0: reg 1c: [mem 0xfb000000-0xfbffffff 64bit]
pci 0000:05:00.0: reg 24: [io 0x8c00-0x8c7f]
pci 0000:05:00.0: reg 30: [mem 0xfcfe0000-0xfcffffff pref]
pci 0000:05:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
pci 0000:00:0e.0: PCI bridge to [bus 05-05]
pci 0000:00:0e.0: bridge window [io 0x8000-0x8fff]
pci 0000:00:0e.0: bridge window [mem 0xfa000000-0xfcffffff]
pci 0000:00:0e.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
pci_bus 0000:00: on NUMA node 0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.HUB0._PRT]
pci0000:00: Unable to request _OSC control (_OSC support mask: 0x1e)
ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 5 7 9 *10 11 12 14 15)
ACPI: PCI Interrupt Link [LNK2] (IRQs 3 4 5 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNK3] (IRQs 3 4 *5 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNK4] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNK5] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LUBA] (IRQs *3 4 5 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LUBB] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LMAC] (IRQs *3 4 5 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LACI] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LMCI] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LSMB] (IRQs 3 4 5 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LUB2] (IRQs 3 4 *5 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LIDE] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LSID] (IRQs 3 4 5 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LFID] (IRQs 3 4 *5 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LPCA] (IRQs 3 4 5 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [APC1] (IRQs 16) *0
ACPI: PCI Interrupt Link [APC2] (IRQs 17) *0
ACPI: PCI Interrupt Link [APC3] (IRQs 18) *0
ACPI: PCI Interrupt Link [APC4] (IRQs 19) *0, disabled.
ACPI: PCI Interrupt Link [APC5] (IRQs *16), disabled.
ACPI: PCI Interrupt Link [APCF] (IRQs 20 21 22 23) *0
ACPI: PCI Interrupt Link [APCG] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCH] (IRQs 20 21 22 23) *0
ACPI: PCI Interrupt Link [APCJ] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCK] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APCS] (IRQs 20 21 22 23) *0
ACPI: PCI Interrupt Link [APCL] (IRQs 20 21 22 23) *0
ACPI: PCI Interrupt Link [APCZ] (IRQs 20 21 22 23) *0, disabled.
ACPI: PCI Interrupt Link [APSI] (IRQs 20 21 22 23) *0
ACPI: PCI Interrupt Link [APSJ] (IRQs 20 21 22 23) *0
ACPI: PCI Interrupt Link [APCP] (IRQs 20 21 22 23) *0, disabled.
vgaarb: device added: PCI:0000:05:00.0,decodes=io+mem,owns=io+mem,locks=none
vgaarb: loaded
vgaarb: bridge control possible 0000:05:00.0
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
PCI: Using ACPI for IRQ routing
PCI: pci_cache_line_size set to 64 bytes
reserve RAM buffer: 000000000009f000 - 000000000009ffff
reserve RAM buffer: 000000007fee0000 - 000000007fffffff
NetLabel: Initializing
NetLabel: domain hash size = 128
NetLabel: protocols = UNLABELED CIPSOv4
NetLabel: unlabeled traffic allowed by default
HPET: 3 timers in total, 0 timers will be used for per-cpu timer
hpet0: at MMIO 0xfefff000, IRQs 2, 8, 31
hpet0: 3 comparators, 32-bit 25.000000 MHz counter
Switching to clocksource hpet
AppArmor: AppArmor Filesystem Enabled
pnp: PnP ACPI init
ACPI: bus type pnp registered
pnp 00:00: [bus 00-05]
pnp 00:00: [io 0x0cf8-0x0cff]
pnp 00:00: [io 0x0000-0x03af window]
pnp 00:00: [io 0x03e0-0x0cf7 window]
pnp 00:00: [io 0x4c00-0x4c7f window]
pnp 00:00: [io 0x8000-0xffff window]
pnp 00:00: [io 0x03b0-0x03df window]
pnp 00:00: [mem 0x000a0000-0x000bffff window]
pnp 00:00: [mem 0x80000000-0xdfffffff window]
pnp 00:00: [mem 0xf0000000-0xfe02ffff window]
pnp 00:00: [mem 0xfeb00000-0xfebfffff window]
pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
pnp 00:01: [io 0x4000-0x407f]
pnp 00:01: [io 0x4080-0x40ff]
pnp 00:01: [io 0x4400-0x447f]
pnp 00:01: [io 0x4480-0x44ff]
pnp 00:01: [io 0x4800-0x487f]
pnp 00:01: [io 0x4880-0x48ff]
system 00:01: [io 0x4000-0x407f] has been reserved
system 00:01: [io 0x4080-0x40ff] has been reserved
system 00:01: [io 0x4400-0x447f] has been reserved
system 00:01: [io 0x4480-0x44ff] has been reserved
system 00:01: [io 0x4800-0x487f] has been reserved
system 00:01: [io 0x4880-0x48ff] has been reserved
system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:02: [io 0x0010-0x001f]
pnp 00:02: [io 0x0022-0x003f]
pnp 00:02: [io 0x0044-0x005f]
pnp 00:02: [io 0x0062-0x0063]
pnp 00:02: [io 0x0065-0x006f]
pnp 00:02: [io 0x0074-0x007f]
pnp 00:02: [io 0x0091-0x0093]
pnp 00:02: [io 0x00a2-0x00bf]
pnp 00:02: [io 0x00e0-0x00ef]
pnp 00:02: [io 0x04d0-0x04d1]
pnp 00:02: [io 0x0800-0x087f]
pnp 00:02: [io 0x0290-0x0297]
system 00:02: [io 0x04d0-0x04d1] has been reserved
system 00:02: [io 0x0800-0x087f] has been reserved
system 00:02: [io 0x0290-0x0297] has been reserved
system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:03: [dma 4]
pnp 00:03: [io 0x0000-0x000f]
pnp 00:03: [io 0x0080-0x0090]
pnp 00:03: [io 0x0094-0x009f]
pnp 00:03: [io 0x00c0-0x00df]
pnp 00:03: Plug and Play ACPI device, IDs PNP0200 (active)
pnp 00:04: [irq 0 disabled]
pnp 00:04: [irq 8]
pnp 00:04: [mem 0xfefff000-0xfefff3ff]
pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
pnp 00:05: [io 0x0070-0x0073]
pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
pnp 00:06: [io 0x0061]
pnp 00:06: Plug and Play ACPI device, IDs PNP0800 (active)
pnp 00:07: [io 0x00f0-0x00ff]
pnp 00:07: [irq 13]
pnp 00:07: Plug and Play ACPI device, IDs PNP0c04 (active)
pnp 00:08: [io 0x03f0-0x03f5]
pnp 00:08: [io 0x03f7]
pnp 00:08: [irq 6]
pnp 00:08: [dma 2]
pnp 00:08: Plug and Play ACPI device, IDs PNP0700 (active)
pnp 00:09: [io 0x03f8-0x03ff]
pnp 00:09: [irq 4]
pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
pnp 00:0a: [io 0x0378-0x037f]
pnp 00:0a: [irq 7]
pnp 00:0a: Plug and Play ACPI device, IDs PNP0400 (active)
pnp 00:0b: [irq 12]
pnp 00:0b: Plug and Play ACPI device, IDs PNP0f13 (active)
pnp 00:0c: [io 0x0060]
pnp 00:0c: [io 0x0064]
pnp 00:0c: [irq 1]
pnp 00:0c: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
pnp 00:0d: [mem 0xe0000000-0xefffffff]
system 00:0d: [mem 0xe0000000-0xefffffff] has been reserved
system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)
pnp 00:0e: [mem 0x000cde00-0x000cffff]
pnp 00:0e: [mem 0x000f0000-0x000f7fff]
pnp 00:0e: [mem 0x000f8000-0x000fbfff]
pnp 00:0e: [mem 0x000fc000-0x000fffff]
pnp 00:0e: [mem 0xfefff000-0xfefff0ff]
pnp 00:0e: [mem 0x7fee0000-0x7fefffff]
pnp 00:0e: [mem 0xffff0000-0xffffffff]
pnp 00:0e: [mem 0x00000000-0x0009ffff]
pnp 00:0e: [mem 0x00100000-0x7fedffff]
pnp 00:0e: [mem 0xfec00000-0xfec00fff]
pnp 00:0e: [mem 0xfee00000-0xfeefffff]
pnp 00:0e: [mem 0xfefff000-0xfeffffff]
pnp 00:0e: [mem 0xfff80000-0xfff80fff]
pnp 00:0e: [mem 0xfff90000-0xfffbffff]
pnp 00:0e: [mem 0xfffed000-0xfffeffff]
system 00:0e: [mem 0x000cde00-0x000cffff] has been reserved
system 00:0e: [mem 0x000f0000-0x000f7fff] could not be reserved
system 00:0e: [mem 0x000f8000-0x000fbfff] could not be reserved
system 00:0e: [mem 0x000fc000-0x000fffff] could not be reserved
system 00:0e: [mem 0xfefff000-0xfefff0ff] has been reserved
system 00:0e: [mem 0x7fee0000-0x7fefffff] could not be reserved
system 00:0e: [mem 0xffff0000-0xffffffff] has been reserved
system 00:0e: [mem 0x00000000-0x0009ffff] could not be reserved
system 00:0e: [mem 0x00100000-0x7fedffff] could not be reserved
system 00:0e: [mem 0xfec00000-0xfec00fff] could not be reserved
system 00:0e: [mem 0xfee00000-0xfeefffff] has been reserved
system 00:0e: [mem 0xfefff000-0xfeffffff] could not be reserved
system 00:0e: [mem 0xfff80000-0xfff80fff] has been reserved
system 00:0e: [mem 0xfff90000-0xfffbffff] has been reserved
system 00:0e: [mem 0xfffed000-0xfffeffff] has been reserved
system 00:0e: Plug and Play ACPI device, IDs PNP0c01 (active)
pnp: PnP ACPI: found 15 devices
ACPI: ACPI bus type pnp unregistered
PnPBIOS: Disabled by ACPI PNP
pci 0000:01:07.0: address space collision: [mem 0xfdfc0000-0xfdfcffff pref] conflicts with 0000:01:06.0 [mem 0xfdfc0000-0xfdfcffff pref]
pci 0000:00:09.0: BAR 15: assigned [mem 0xfe100000-0xfe1fffff pref]
pci 0000:01:07.0: BAR 6: assigned [mem 0xfe100000-0xfe10ffff pref]
pci 0000:00:09.0: bridge window [mem 0xfe100000-0xfe1fffff pref]
pci 0000:00:09.0: setting latency timer to 64
pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
pci_bus 0000:00: resource 5 [mem 0x000a0000-0x000bffff]
pci_bus 0000:00: resource 6 [mem 0xfe030000-0xffffffff]
pci_bus 0000:00: resource 7 [mem 0x80000000-0xefffffff]
pci_bus 0000:00: resource 8 [mem 0xf0000000-0xfe02ffff]
pci_bus 0000:01: resource 0 [io 0x9000-0xafff]
pci_bus 0000:01: resource 1 [mem 0xfdf00000-0xfdffffff]
pci_bus 0000:01: resource 2 [mem 0xfe100000-0xfe1fffff pref]
pci_bus 0000:01: resource 4 [io 0x0000-0xffff]
pci_bus 0000:01: resource 5 [mem 0x000a0000-0x000bffff]
pci_bus 0000:01: resource 6 [mem 0xfe030000-0xffffffff]
pci_bus 0000:01: resource 7 [mem 0x80000000-0xefffffff]
pci_bus 0000:01: resource 8 [mem 0xf0000000-0xfe02ffff]
pci_bus 0000:05: resource 0 [io 0x8000-0x8fff]
pci_bus 0000:05: resource 1 [mem 0xfa000000-0xfcffffff]
pci_bus 0000:05: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
ACPI: PCI Interrupt Link [APCF] enabled at IRQ 23
ACPI: PCI Interrupt Link [APCL] enabled at IRQ 22
pci 0000:00:00.0: Found enabled HT MSI Mapping
pci 0000:00:0b.0: Found disabled HT MSI Mapping
pci 0000:00:0c.0: Found disabled HT MSI Mapping
pci 0000:00:0d.0: Found disabled HT MSI Mapping
pci 0000:00:0e.0: Found disabled HT MSI Mapping
pci 0000:05:00.0: Boot video device
PCI: CLS 32 bytes, default 64
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 13004k freed
audit: initializing netlink socket (disabled)
type=2000 audit(1392547368.563:1): initialized
highmem bounce pool size: 64 pages
HugeTLB registered 4 MB page size, pre-allocated 0 pages
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
fuse init (API version 7.18)
msgmni has been set to 1726
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered (default)
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
pciehp: PCI Express Hot Plug Controller Driver version: 0.4
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Linux agpgart interface v0.103
brd: module loaded
loop: module loaded
pata_acpi 0000:00:06.0: setting latency timer to 64
ACPI: PCI Interrupt Link [APSI] enabled at IRQ 21
pata_acpi 0000:00:07.0: setting latency timer to 64
ACPI: PCI Interrupt Link [APSJ] enabled at IRQ 20
pata_acpi 0000:00:08.0: setting latency timer to 64
Fixed MDIO Bus: probed
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <This email address is being protected from spambots. You need JavaScript enabled to view it.>
PPP generic driver version 2.4.2
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci_hcd 0000:00:02.1: setting latency timer to 64
ehci_hcd 0000:00:02.1: EHCI Host Controller
ehci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:02.1: debug port 1
ehci_hcd 0000:00:02.1: cache line size of 32 is not supported
ehci_hcd 0000:00:02.1: irq 22, io mem 0xfeb00000
ehci_hcd 0000:00:02.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 9 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci_hcd 0000:00:02.0: setting latency timer to 64
ohci_hcd 0000:00:02.0: OHCI Host Controller
ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:02.0: irq 23, io mem 0xfe02f000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 9 ports detected
uhci_hcd: USB Universal Host Controller Interface driver
usbcore: registered new interface driver libusual
i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
mousedev: PS/2 mouse device common for all mice
rtc_cmos 00:05: RTC can wake from S4
rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
rtc0: alarms up to one year, y3k, 242 bytes nvram, hpet irqs
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: This email address is being protected from spambots. You need JavaScript enabled to view it.
EISA: Probing bus 0 at eisa.0
EISA: Cannot allocate resource for mainboard
Cannot allocate resource for EISA slot 1
Cannot allocate resource for EISA slot 2
Cannot allocate resource for EISA slot 3
Cannot allocate resource for EISA slot 4
Cannot allocate resource for EISA slot 5
Cannot allocate resource for EISA slot 6
Cannot allocate resource for EISA slot 7
Cannot allocate resource for EISA slot 8
EISA: Detected 0 cards.
EFI Variables Facility v0.08 2004-May-17
TCP: cubic registered
NET: Registered protocol family 10
NET: Registered protocol family 17
Registering the dns_resolver key type
Using IPI Shortcut mode
registered taskstats version 1
rtc_cmos 00:05: setting system clock to 2014-02-16 10:42:49 UTC (1392547369)
BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
EDD information not available.
Freeing unused kernel memory: 544k freed
input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
udevd[77]: starting version 175
forcedeth: Reverse Engineered nForce ethernet driver. Version 0.64.
ACPI: PCI Interrupt Link [APCH] enabled at IRQ 23
forcedeth 0000:00:0a.0: setting latency timer to 64
ACPI: PCI Interrupt Link [APC2] enabled at IRQ 17
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
firewire_ohci 0000:01:01.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x11
usb 2-1: new full-speed USB device number 2 using ohci_hcd
forcedeth 0000:00:0a.0: ifname eth0, PHY OUI 0x1374 @ 0, addr 00:18:f3:be:5d:42
forcedeth 0000:00:0a.0: highdma csum gbit lnktim desc-v3
sata_nv 0000:00:07.0: version 3.5
sata_nv 0000:00:07.0: setting latency timer to 64
scsi0 : sata_nv
scsi1 : sata_nv
ata1: SATA max UDMA/133 cmd 0x9f0 ctl 0xbf0 bmdma 0xd400 irq 21
ata2: SATA max UDMA/133 cmd 0x970 ctl 0xb70 bmdma 0xd408 irq 21
sata_nv 0000:00:08.0: setting latency timer to 64
scsi2 : sata_nv
scsi3 : sata_nv
ata3: SATA max UDMA/133 cmd 0x9e0 ctl 0xbe0 bmdma 0xc000 irq 20
ata4: SATA max UDMA/133 cmd 0x960 ctl 0xb60 bmdma 0xc008 irq 20
pata_amd 0000:00:06.0: version 0.4.1
pata_amd 0000:00:06.0: setting latency timer to 64
scsi4 : pata_amd
scsi5 : pata_amd
ata5: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xe800 irq 14
ata6: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xe808 irq 15
firewire_core 0000:01:01.0: created device fw0: GUID 0011d80000924dcf, S400
ata5.00: ATA-6: WDC WD1600BB-00GUA0, 08.02D08, max UDMA/100
ata5.00: 312581808 sectors, multi 1: LBA48
ata5: nv_mode_filter: 0x3f39f&0x3f39f->0x3f39f, BIOS=0x3f000 (0xc6000000) ACPI=0x3f01f (20:600:0x13)
ata5.00: configured for UDMA/100
ata1: SATA link down (SStatus 0 SControl 300)
ata3: SATA link down (SStatus 0 SControl 300)
usb 2-7: new full-speed USB device number 3 using ohci_hcd
ata2: SATA link down (SStatus 0 SControl 300)
ata4: SATA link down (SStatus 0 SControl 300)
scsi 4:0:0:0: Direct-Access ATA WDC WD1600BB-00G 08.0 PQ: 0 ANSI: 5
sd 4:0:0:0: Attached scsi generic sg0 type 0
sd 4:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
sd 4:0:0:0: [sda] Write Protect is off
sd 4:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 4:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1 sda2 < sda5 >
sd 4:0:0:0: [sda] Attached SCSI disk
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
init: ureadahead main process (301) terminated with status 5
Adding 2094076k swap on /dev/sda5. Priority:-1 extents:1 across:2094076k
udevd[375]: starting version 175
lp: driver loaded but no devices found
EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
parport_pc 00:0a: reported by Plug and Play ACPI
parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
lp0: using parport0 (interrupt-driven).
input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
ACPI: Power Button [PWRB]
input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
ACPI: Power Button [PWRF]
ppdev: user-space parallel port driver
k8temp 0000:00:18.3: Temperature readouts might be wrong - check erratum #141
wmi: Mapper loaded
microcode: AMD CPU family 0xf not supported
i2c i2c-0: nForce2 SMBus adapter at 0x4c00
i2c i2c-1: nForce2 SMBus adapter at 0x4c40
ACPI: PCI Interrupt Link [APC1] enabled at IRQ 16
Trying to free nonexistent resource <000000000000a800-000000000000a8ff>
net2272: probe of 0000:01:06.0 failed with error -16
Trying to free nonexistent resource <000000000000a000-000000000000a0ff>
net2272: probe of 0000:01:07.0 failed with error -16
input: Packard Bell Viseo 200T as /devices/pci0000:00/0000:00:02.0/usb2/2-1/2-1:1.0/input/input3
hid-multitouch 0003:0408:3000.0001: input,hidraw0: USB HID v1.10 Device [Packard Bell Viseo 200T] on usb-0000:00:02.0-1/input0
psmouse serio1: logips2pp: Detected unknown Logitech mouse model 89
[drm] Initialized drm 1.1.0 20060810
input: ImExPS/2 Logitech Explorer Mouse as /devices/platform/i8042/serio1/input/input4
ACPI: PCI Interrupt Link [APC3] enabled at IRQ 18
[drm] nouveau 0000:05:00.0: Detected an NV40 generation card (0x04b200b1)
[drm] nouveau 0000:05:00.0: Checking PRAMIN for VBIOS
[drm] nouveau 0000:05:00.0: ... appears to be valid
[drm] nouveau 0000:05:00.0: Using VBIOS from PRAMIN
[drm] nouveau 0000:05:00.0: BIT BIOS found
[drm] nouveau 0000:05:00.0: Bios version 05.73.22.54
[drm] nouveau 0000:05:00.0: TMDS table version 1.1
[drm] nouveau 0000:05:00.0: TMDS table script pointers not stubbed
[drm] nouveau 0000:05:00.0: MXM: no VBIOS data, nothing to do
[drm] nouveau 0000:05:00.0: DCB version 3.0
[drm] nouveau 0000:05:00.0: DCB outp 00: 01000300 00000028
[drm] nouveau 0000:05:00.0: DCB outp 01: 03011312 00000000
[drm] nouveau 0000:05:00.0: DCB outp 02: 04011310 00000028
[drm] nouveau 0000:05:00.0: DCB outp 03: 020223f1 00c0c080
[drm] nouveau 0000:05:00.0: DCB conn 00: 1030
[drm] nouveau 0000:05:00.0: DCB conn 01: 0100
[drm] nouveau 0000:05:00.0: DCB conn 02: 0210
[drm] nouveau 0000:05:00.0: DCB conn 03: 0211
[drm] nouveau 0000:05:00.0: DCB conn 04: 0213
[drm] nouveau 0000:05:00.0: Parsing VBIOS init table 0 at offset 0xCE0D
[drm] nouveau 0000:05:00.0: Parsing VBIOS init table 1 at offset 0xD4B7
[drm] nouveau 0000:05:00.0: Parsing VBIOS init table 2 at offset 0xDBEB
[drm] nouveau 0000:05:00.0: Parsing VBIOS init table 3 at offset 0xDD6F
[drm] nouveau 0000:05:00.0: Parsing VBIOS init table 4 at offset 0xDF7B
[TTM] Zone kernel: Available graphics memory: 442324 kiB
[TTM] Zone highmem: Available graphics memory: 1035672 kiB
[TTM] Initializing pool allocator
[drm] nouveau 0000:05:00.0: Detected 512MiB VRAM (DDR2)
[drm] nouveau 0000:05:00.0: 512 MiB GART (aperture)
[drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[drm] No driver support for vblank timestamp query.
[drm] nouveau 0000:05:00.0: 1 available performance level(s)
[drm] nouveau 0000:05:00.0: 0: core 400MHz shader 400MHz memory 270MHz voltage 1170mV fanspeed 100%
[drm] nouveau 0000:05:00.0: c: core 400MHz shader 400MHz memory 270MHz
[drm] nouveau 0000:05:00.0: 0xC25D: Parsing digital output script table
[drm] nouveau 0000:05:00.0: Setting dpms mode 3 on TV encoder (output 3)
composite sync not supported
[drm] nouveau 0000:05:00.0: allocated 1600x900 fb: 0x49000, bo f6ea6200
fbcon: nouveaufb (fb0) is primary device
Console: switching to colour frame buffer device 200x56
fb0: nouveaufb frame buffer device
drm: registered panic notifier
[drm] Initialized nouveau 1.0.0 20120316 for 0000:05:00.0 on minor 0
usb_audio: Warning! Unlikely big volume range (=8065), cval->res is probably wrong.
usb_audio: [9] FU [Mic Playback Volume] ch = 2, val = -6144/1921/1
usb_audio: [14] FU [CD Playback Volume] ch = 2, val = -6144/1921/1
usb_audio: [11] FU [Line Playback Volume] ch = 2, val = -6144/1921/1
usb_audio: Warning! Unlikely big volume range (=6928), cval->res is probably wrong.
usb_audio: [8] FU [Mic Capture Volume] ch = 2, val = -4096/2832/1
usb_audio: [2] FU [PCM Capture Volume] ch = 2, val = -4096/2832/1
usb_audio: [16] FU [CD Capture Volume] ch = 2, val = -4096/2832/1
usb_audio: [15] FU [Line Capture Volume] ch = 2, val = -4096/2832/1
usbcore: registered new interface driver snd-usb-audio
type=1400 audit(1392547382.350:2): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=718 comm="apparmor_parser"
type=1400 audit(1392547382.350:3): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=718 comm="apparmor_parser"
type=1400 audit(1392547382.350:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=718 comm="apparmor_parser"
type=1400 audit(1392547382.350:5): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=719 comm="apparmor_parser"
type=1400 audit(1392547382.351:6): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=719 comm="apparmor_parser"
type=1400 audit(1392547382.351:7): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=719 comm="apparmor_parser"
init: failsafe main process (791) killed by TERM signal
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
type=1400 audit(1392547387.094:8): apparmor="STATUS" operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" pid=882 comm="apparmor_parser"
type=1400 audit(1392547387.094:9): apparmor="STATUS" operation="profile_load" name="/usr/sbin/cupsd" pid=882 comm="apparmor_parser"
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
type=1400 audit(1392547390.591:10): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=941 comm="apparmor_parser"
type=1400 audit(1392547390.592:11): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=941 comm="apparmor_parser"
type=1400 audit(1392547390.592:12): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=941 comm="apparmor_parser"
type=1400 audit(1392547390.829:13): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper" pid=940 comm="apparmor_parser"
type=1400 audit(1392547390.830:14): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper//chromium_browser" pid=940 comm="apparmor_parser"
type=1400 audit(1392547391.080:15): apparmor="STATUS" operation="profile_load" name="/usr/lib/telepathy/mission-control-5" pid=945 comm="apparmor_parser"
type=1400 audit(1392547391.080:16): apparmor="STATUS" operation="profile_load" name="/usr/lib/telepathy/telepathy-*" pid=945 comm="apparmor_parser"
type=1400 audit(1392547391.084:17): apparmor="STATUS" operation="profile_replace" name="/usr/lib/cups/backend/cups-pdf" pid=948 comm="apparmor_parser"
type=1400 audit(1392547391.085:18): apparmor="STATUS" operation="profile_replace" name="/usr/sbin/cupsd" pid=948 comm="apparmor_parser"
type=1400 audit(1392547391.258:19): apparmor="STATUS" operation="profile_load" name="/usr/sbin/tcpdump" pid=950 comm="apparmor_parser"
I-pipe: head domain RTAI registered.
RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 12565879, CLK_FREQ 2211236000, CPU_FREQ 2211236000
RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12565879, 12565879, 12390000
RTAI[malloc]: global heap size = 131072 bytes, <BSD>.
, <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
RTAI[sched]: hard timer type/freq = APIC/12565879(Hz); default timing: periodic; linear timed lists.
RTAI[sched]: Linux timer freq = 1000 (Hz), TimeBase freq = 2211236000 hz.
RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
***** WARNING: GLOBAL HEAP NEITHER SHARABLE NOR USABLE FROM USER SPACE (use the vmalloc option for RTAI malloc) *****
RTAI[math]: loaded.
hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
hm2_pci: discovered 5i22-1.5M at 0000:01:06.0
hm2/hm2_5i22.0: firmware hm2/5i22/SVST8_8S.BIT not found
hm2/hm2_5i22.0: install the package containing the firmware.
hm2_5i22.0: board fails HM2 registration
hm2_pci: probe of 0000:01:06.0 failed with error -2
hm2_pci: discovered 5i22-1.5M at 0000:01:07.0
hm2/hm2_5i22.1: firmware hm2/5i22/SVST8_8S.BIT not found
hm2/hm2_5i22.1: install the package containing the firmware.
hm2_5i22.1: board fails HM2 registration
hm2_pci: probe of 0000:01:07.0 failed with error -2
hm2: unloading
RTAI[math]: unloaded.
RTAI[malloc]: unloaded.
RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
I-pipe: head domain RTAI unregistered.
RTAI[hal]: unmounted.
TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12565879, 12565879, 12432000
RTAI[math]: loaded.
hm2/hm2_5i22.0: firmware hm2/5i22/SVST8_8B.BIT not found
hm2/hm2_5i22.1: firmware hm2/5i22/SVST8_8B.BIT not found
hm2: unloading
TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12565879, 12565879, 12320000
RTAI[math]: loaded.
hm2/hm2_5i22.0: board has FPGA '3s1500fg320', but the firmware in hm2/5i23/SVST8_4.BIT is for FPGA '3s400pq208'
hm2_pci: probe of 0000:01:06.0 failed with error -22
hm2/hm2_5i22.1: board has FPGA '3s1500fg320', but the firmware in hm2/5i23/SVST8_4.BIT is for FPGA '3s400pq208'
hm2_pci: probe of 0000:01:07.0 failed with error -22
hm2: unloading
TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12565879, 12565879, 12421000
RTAI[math]: loaded.
config string '0x378 in '
tool: module license 'GPLv2 or later' taints kernel.
Disabling lock debugging due to kernel taint
hm2/hm2_5i22.0: board has FPGA '3s1500fg320', but the firmware in hm2/5i20/SVST8_4.BIT is for FPGA '2s200pq208'
hm2/hm2_5i22.1: board has FPGA '3s1500fg320', but the firmware in hm2/5i20/SVST8_4.BIT is for FPGA '2s200pq208'
hm2: unloading
TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12565879, 12565879, 12357000
RTAI[math]: loaded.
TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12565879, 12565879, 12368000
RTAI[math]: loaded.
hm2: unloading
TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12565879, 12565879, 12427000
RTAI[math]: loaded.
hm2: unloading
- emcPT
- Thank you received: 139
That is quite similar to the thread:
www.linuxcnc.org/index.php/english/forum...r-inserting-hm2pciko
I belive that you miss the .BIT files on the right place.
- tld70
the 5i20 board will work,
OK I copied the files to the place, but no change,
only the 5i20 board work, the 5i22 not ( I only have one of this boards in the Computer )
- Thank you received: 5255
I would suggest that you clear the kernel log with:
sudo dmesg -c
and then run linuxcnc again and search for 5I22 in the kernel log to determine what the error is
- tld70
then there is a fault in the sample config Files from Linuxcnc
the file creates
CONFIG="firmware=hm2/5i22/SVST8_8B.BIT num_encoders=3 num_pwmgens=3 num_stepgens=0"
but there is no file like this.
I changed it to:
CONFIG="firmware=hm2/5i22-1.5/SVST8_8.BIT num_encoders=3 num_pwmgens=3 num_stepgens=0"
and it works
Thomas
